How do you convert to the Vette accessories?
Old Nov 11, 2013 | 04:35 PM
JimMueller's Avatar
Default How do you convert to the Vette accessories?
Looking at a change which would require switching over to the Vette accessory spacing. Is it as simple as buying new brackets/pulleys, or do I need the whole new alternator, PS pump, etc?
Old Nov 12, 2013 | 08:43 AM
thunderstruck507's Avatar
I am fairly certain you need everything
Old Nov 18, 2013 | 04:12 PM
jlcustomz's Avatar
Street & performance should have some used take off stock. entire system is spaced differently from engine between F-body, vette & truck setup. You will need balancer, water pump may be ok.Alternators should swap. PS pump on vette has remote reservoir.
Old Nov 18, 2013 | 09:04 PM
1981TA's Avatar
You need everything. If you do decide to pull the trigger on the switchover, I have a stock c5 crank pulley available. I'd get a new or rebuild water pump and keep in mind there is a revised design for newer vettes that places the water outlet for the radiator on the driver side of the pump pulley. Older ones like mine have the outlet on the passenger side of the pump pulley. They all bolt in the same way, but at least you have a couple hose routing options, depending on the pump you get.
