Ordered Kurt Urban steam vent setup
Old Nov 13, 2013 | 12:40 PM
roninsonic's Avatar
Default Ordered Kurt Urban steam vent setup
Well... I went ahead, bit the bullet, and ordered the Kurt Urban Performance steam vent setup. Although it's not really NEEDED right now, it looks pretty and WILL be when I get done piecing together my F1A/346/4L80E build.
After doing a LOT of research of how to best make a plug and play setup (there seems to be a lot of discussion on where the steam vent return should go), I've put together a complete list of parts needed for the install.
-KUP steam vent kit w/optional bracket & FAST option (there is no reason NOT to get the FAST/LS7 option... It costs the same and leaves room if you swap intakes later)
-Jags That Run LS1 upper radiator hose connector with vent and steam line tee
-1/8NPT to -4AN 90deg connector
-90deg -4AN Push-Loc hose end
-Straight -4AN Push-Loc hose end
-10 feet -4AN Push-Loc hose
The plan-
-Install the KUP kit with the supplied bracket
-Remove barb fitting from the JTR piece and install 1/8NPT to -4AN 90deg connector in it's place
-Splice JTR piece into upper radiator hose
-Install straight -4AN Push-Loc fitting on one side of hose, connect it to the -4AN connector on JTR piece
-Route hose until satisfied with layout, cut hose, install the other -4AN Push-Loc fitting on hose
-Burp coolant system and sleep easy.
Can anyone think of something that I'm missing? (I hope not. everything's already ordered )
If there's any interest, I'll post up pictures after I do the install, along with links to where parts can be purchased.
Old Nov 13, 2013 | 02:03 PM
BrntWS6's Avatar
I need to do this too but not spending that kind of coin on it. Plus it looks like it would be in the way if I ever did a plate kit. I like what one member did and hammer down the OEM tubes to fit under a FAST 92 intake. But I don't think that can be bought anymore so you'd have to find one in a junk yard if you have an 01-02.
Old Nov 13, 2013 | 03:00 PM
roninsonic's Avatar
I'm not really seeing how it would get in the way with a plate kit...
where are you thinking it would interfere? Just wondering.
Old Nov 13, 2013 | 03:42 PM
LS1MCSS's Avatar
Everybody calls those steam vents and I have never figured out why. If you ever watch one run, without the radiator cap, you'll see that it's not steam coming from them. It's a fast flowing stream of water.
Old Nov 13, 2013 | 04:01 PM
BrntWS6's Avatar
It looked like it would interfere with the solenoids that mount by the fuel rails.
Old Nov 14, 2013 | 05:43 AM
roninsonic's Avatar
AHHH ok.
Honestly, you can mount noids just about anywhere... All it takes is some sheet aluminum, a drill, a and a vice. Make your own mount There are also several pre-made noid mounts available from some of the sponsors. The only reason I paid for the 25 bucks for the KUP mount is because I know it'll fit right and for 25 dollars it's just not worth it for me to dick with making my own.
Old Nov 14, 2013 | 07:02 PM
BrntWS6's Avatar
Oh.....I didn't realize you could purchase the mount for the kup separate.
Old Nov 14, 2013 | 07:06 PM
speedtigger's Avatar
Old School Heavy
It is because they prevent air pockets.
Old Dec 5, 2013 | 05:40 AM
Patsy57's Avatar
How did this work out? Any issues with your plan or did it mount up exactly how you wanted it? Can you post pics?
Thanks!
Old Dec 11, 2013 | 12:47 AM
roninsonic's Avatar
sorry y'all, haven't been on tech for a bit (PCS'ing to another duty station)
I actually got my orders today, so tomorrow night or maybe the next day I'll actually see my baby for the first time in over a year. Deployment SUCKS... But all that money sure bought a lot of car parts!
I'll post up some pictures when I get the setup done. Shouldn't be too hard, I don't think.
Old Dec 11, 2013 | 09:34 AM
JakeFusion's Avatar
Super Hulk Smash
That Kurt Urban setup looks nice... I might have to get that.
Old Dec 19, 2013 | 10:25 AM
roninsonic's Avatar
UPDATE: The setup is on (along with PRC .650" valve springs, !EVAP, and a bunch of other ****)
As soon as the intake goes back on and I make the AN line going from the steam vent collection block to the upper radiator hose, I'll post up some pictures.
Old Dec 19, 2013 | 10:36 AM
themealonwheels's Avatar
I'll be interested to see how the front DS fitting fits with the FAST intake. I have a FAST 102 and I'm putting together my own -4AN system. I haven't received my 90 degree hose end for the DS front yet, but I can foresee a tight fit IF it fits...
Old Dec 19, 2013 | 11:52 AM
Patsy57's Avatar
I am as well, I have the same setup of course bought the Kurt Urban product though..
Old Dec 20, 2013 | 06:17 AM
It won't fit on the front DS with a FAST 102. I tried an Alpine motorsports 4AN straight with a 90 hose end without success, then I tried a GETFAST1 block with a 90 1/8NPT to 4AN, both touched the corner of the intake. Finally I said f*** it and put the stock modified crossover I had back on and tied it into the rear line going to the radiator. I am pissed, I spent so much money on fittings...
Old Dec 20, 2013 | 06:23 AM
Old Dec 21, 2013 | 01:28 AM
xrannie's Avatar
the 102's are shaped differently there than the 90/92's. Their website actually has an option when ordering for the 102's. It was no extra and I wasn't sure, so I clicked it... Turns out it wasn't needed.
A lifter died last night shortly after startup, and when pulling the heads today I noticed something interesting about the 45 degree fittings they supply for the 102's vs straight fittings- The small head bolts won't clear the straight fittings (fittings have to be removed), but WILL clear the 45 degrees with them clocked for the FAST.
Old Dec 24, 2013 | 08:37 AM
Patsy57's Avatar
Pics?
Old Dec 24, 2013 | 09:13 AM
Undertow74's Avatar
Yea same **** with my when I installed it over a year ago. What I wound up doing was putting a stock front crossover on the rear, running a rubber hose around the front, and used the Kurt urban water block to tie the 2 rubber lines in and then ran it to the radiator. I capped off the extra port on the block. It still looks clean and the way I routed it you can't even see it.
Old Dec 26, 2013 | 10:00 AM
Interesting, I did something similar originally: two front crossovers tied together returning to the radiator. I ended up pursuing an -AN setup when I discovered a puddle of coolant on the floor from behind my intake. I guess the intake and firewall had forced the front crossover on the back to rub and eventually leak.
Anyway, I now have an -AN setup in the back tying to the stock front crossover modified in the front.
OP, sorry about the hijack...
