Super Vic., Edelbrock Pro Flow XT, Holley High or Mid Rise Intake For Max Effort 346
#61
#64
Like I've said a thousand times, if you don't have the right cam for a single plane intake setup, then you're wasting your ******* time. I don't know why people can't understand that. That lower RPM **** can be taken care of easily if you have the right cam with the right valve events.
Not sure if this was directed at me but for what I was using the car for, it was not a crappy setup at all. To come out and run door to door and beat cam cars is pretty impressive I think and so did everyone else that raced it. Not saying the setup was "optimized" but for a bone stock motor, it worked very well. I could care less about low end and midrange power in a drag race because I don't use it. It's not a road race car.
#65
I was not inferring that your car was crappy in any way at all sir. But for what it's worth with a first version Texas Speed Torquer Cam and a set of LT headers it made 409/384 (stock heads) back 10 years ago. Never ran the car at the track with that setup but with 4.10 gears it ran like a scalded dog. Car would not hook up at all. Slicks would have made it hook but I didn't feel like tearing up the weakazz 10 bolt. But with a well thought out collection of mods (H/C & ATBOs )and a much smaller custom cam it made 452/418 without a fast intake and TB. After hot rodding for 50+ years I kinda got it figured out by now.
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
#66
I was not inferring that your car was crappy in any way at all sir. But for what it's worth with a first version Texas Speed Torquer Cam and a set of LT headers it made 409/384 (stock heads) back 10 years ago. Never ran the car at the track with that setup but with 4.10 gears it ran like a scalded dog. Car would not hook up at all. Slicks would have made it hook but I didn't feel like tearing up the weakazz 10 bolt. But with a well thought out collection of mods (H/C & ATBOs )and a much smaller custom cam it made 452/418 without a fast intake and TB. After hot rodding for 50+ years I kinda got it figured out by now.![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
The only reason I posted was to show that these single plane intakes make power and I was posting my experience with it and states that it worked in my application. Also that if it had a cam in it that was made for that intake setup that the power would have been amazing and if I was looking to build a max effort 346 then I'd take the single plane hands down.
#67
All I can say is when I do the Super Vic./4150 TB swap, my existing cam will be coming out in lue of a custom cam that is spec'd for the Super Vic./4150 TB, not to mention the rest of the setup (heads, gears, 6 speed, car weight, etc.). Will the cam I have now work; yeah, probably. Will it be optimal; hell no. I'm one of those guys that can't just half *** something; it's all or nothing with me. When I lift weights, it's ***** to the wall. When I drink, it sure as hell ain't to get a buzz. Same philosophy with my car.
#68
Wasn't pointing anyone out exclusively... Just sayin there is a lot of crap out there... I set out to do a single plane from the jump, used stock 317's had them milled .075 gave me a 61.5cc chamber, a simple 250/250 hyd roller and it made quite a bit more than a lot of combos.. Been beating the snot outta it for 2yrs.. Finally putting some heads on it looking to go north of 5xxwhp.. I'm building another 346 for someone.. Single plane deal... Expecting it to go pretty well..
#72
IllusionalTA, on a 346, if the cam is optimal for whichever intake, how would the Pro Flow compare to the Super Vic.? How different is the RPM ramge between the two? Would the Pro Flow be even better in the upper RPM range over the Super Vic., or would it yield better lower RPM power/torque?
#73
#76
I couldn't tell ya, I'd say pick your intake and run it... This is all guesswork, I know mine works just fine, and I'll continue to build off what I got... I'm doubtful, that I'll find any significant gains goin from my single plane to that thing... If someone would like to send me one to test, I'll gladly do that... But we're nickel and diming at this point...
#77
I'm sure whichever intake you decide to go with will work out nice for you esp. if your getting a cam designed for it. I would probably still be running a FAST intake if I didn't get convinced I should go single plane. Glad I decided to go Super Vic honestly....seen them perform nicely out of the box, And not that it matters but I think they look better too lol
#78
Another reason why I'm leaning toward the Super Vic./4150 TB is because I could run the Nitrous Outlet Stinger Plate setup. With the Pro Flo, it would be their traditional 90/100mm plate setup.
#79
I think there is more potential in the single plane! Ported super Vic with the combo all good and a plate on top of it!! About as good as you can get without spending top dollar. Mast,sheet metal etc. I keep thinkin selling my fast and going single plane with a puck.
#80
