Problem: Ls1 slp underdrive pulley on lq4
Old Dec 17, 2013 | 10:47 AM
Good2goWS6's Avatar
Default Problem: Ls1 slp underdrive pulley on lq4
I bought the power bond slp underdrive pulley for a 5.7 ls1 for my 6.0 lq4 and even as tight as I can get it on it still won't line up close enough for the belt to go on. Any ideas?
Old Dec 17, 2013 | 05:03 PM
Rob WS6's Avatar
If you're using LS1 front accessories, it should work as long as its the correct balancer. Take it off and compare it to the stock one. They could have sent you the wrong one!
Old Dec 17, 2013 | 06:23 PM
01ssreda4's Avatar
What the hell do you mean as tight as you can get it? Its either on correctly or it isn't. No two ways about it. Install it correctly and get back to us.
Old Dec 17, 2013 | 06:29 PM
ramairetransam's Avatar
heat it up in the oven or water and then install it .
