Need help installing TSP ORY, Help!!!
Old Dec 18, 2013 | 08:50 PM
ls1mustang00's Avatar
Default Need help installing TSP ORY, Help!!!
I just recently bought 1 3/4 tsp headers, tsp ory, and magnaflow catback. I am in the process of installing everything and after doing the headers with no issues i am currently stuck on the ory install. The driver side header did not let me insert the first pipe on the ory because it was angled towards the floor pan so i loosened the header bolts(on both sides) and then managed to insert it. The problem is that it touches the floor pan and i am not sure if it is supposed to. And on the passenger side, the long pipe where it connects to the merge, didnt go in very straight or flush and because it goes in at an angle it has an opening that i dont think will close when i tighten the clamps. So do you guys have any suggestions? Would tightening the headers align the ory the way its supposed be?
Old Dec 19, 2013 | 06:09 AM
Mista Blazer's Avatar
At no point should the exhaust hit the body, it will/could trigger the knock sensors and cause it to pull timing. Sounds like it got bent wrong at one time id call the people that you bought it from
Old Dec 19, 2013 | 08:42 AM
I bought it from texas speed and performance
Old Dec 19, 2013 | 08:44 AM
I guess i can try messing around with it some more before i give up and call them
