ASP Pulley FELL OFF!
Do you think that the people that installed the pulley are at least liable for my $125 tow? Liable for the price I will pay another shop to "reinstall", and last, but not least, if there is actual damage to the pulley, do they owe me another? I have to figure out how I am going to approach this by 2PM CST today before I go over there. They are at least gonna get a piece of my mind.
James Coker
PS sorry so long winded
You should always use a new bolt, since GM uses "Torque-to-yield" crank bolts on the LS1. That means the bolt is over-tightened on purpose to the yield point, causing bolt stretch. They shouldn't be reused since they have been to the limit on their original installation.
Don't use loc-tite on that crank bolt either, you want to be able to remove it later. Sounds like they didn't get it on far enough or torque the bolt properly.
Al
I would think the shop responsible since they should know that you need a new GM bolt whenever you R&R the crank pulley.
Al
James Coker
unless the shop has done tons of these installs i always supply directions if possible.not to be insulting but to helpful and to avoid situations like this.
