LS1 IAC valve and High Idle
After I replaced the IAC the idle was still the same so I removed the IAC and turned the ignition on to see if it moved...didnt move, proceeded to start...still didnt move. I dont believe the IAC is bad, but who knows. Is there a way to test the IAC? Is there a procedure that needs to be done when installing a new IAC?? I would think that it would still move even if I didnt..
The car has AIR and EGR delete with longtubes and I dont believe the ECM was tuned for the deletes...could this be the issue? Any help is greatly appreciated. The car is a 98 Formula.
Its foolish to speak this way, but at this point I wouldnt mind going back completely stock..stock manifolds, stock y pipe, egr and air installed. I just want a vehicle that functions as it should. Personally I dont see the point of deleting the EGR the gain is very minute, if any, and is mainly for aeshetics...to me thats not worth it if the vehicle isnt going to idle right.
I'll move this down to the Gen III External Engine section in hopes for some more ideas...
