Dumb question
Old Jan 17, 2014 | 03:17 AM
Bad28's Avatar
Default Dumb question
Ok I have heads cam and all the basic bolt ons my question is I have an ls2 intake sitting in the garage would it be better to have it ported and use it or sell it and buy an ls6 intake if I keep the ls2 intake what all will I need to make it work on my 2000 camaro z28
Old Jan 17, 2014 | 03:53 AM
Burken01's Avatar
Sell it and get a ls6, it's proven to outflow the ls2..
Old Jan 17, 2014 | 04:20 AM
Bad28's Avatar
I know stock for stock ls6 wins out but ported to ported the ls2 is superior just didn't know if it's worth the $ to have ported
Old Jan 17, 2014 | 08:26 AM
LS1-450's Avatar
You can do it yourself. The key is to carefully get rid of the ridges in the runners & then just port match to head ports.
Old Jan 17, 2014 | 02:43 PM
Bad28's Avatar
Ok do you know what all is needed to make it work I know rails injectors tb and a dbw bracket
Old Jan 22, 2014 | 04:10 PM
Stoner_Banks's Avatar
i actually went through a situation like this not long ago.
I have a 99 ls1 with an aluminum ls2 intake so i ported the **** out of it! haha
but one thing that your going to have to remember is if your going ls2 intake then you have to go ls2 TB as well meaning 96mm^ and it must be a 4bolt rather than our traditional 3bolt.
your better or getting a custom 4 bolt pattern ls2 TB which is drive by cable not DBW!
and going DBW is alot more complicated, having to buy a wiring harness adapter for the conversion and you must have your TB calibrated properly due to having the pedal actually control your plate now.
1999 z28 camaro ls6 cam & crank, hardened pushrods&rockers,ported 853's (past 241's) 3.43, ls2 intake, 101mmTB, fast fuel rails, 32# inj, LT's, X-pipe, dynomax bullet mufflers,
Old Jan 22, 2014 | 06:35 PM
HCI2000SS's Avatar
So you're saying a ported LS2 intake out flows a ported LS6? I've never heard that
Old Jan 23, 2014 | 04:40 PM
Burken01's Avatar
It's worthless to port a ls6, the gains are teeny tiny
