FAST 102 on LS1?
Old Jan 27, 2014 | 10:51 PM
metlic53's Avatar
Originally Posted by lemons12
I laughed because it was a random number... Not 1200... Not 1300... But 1250hp.
For no budget that's an extremely low number. You can make over 1000 with a 347 and stock 317 heads stock ls6 intake stock throttle body and a baby cam. I don't consider that a no budget build... That's a whopping 400-500$ in the complete top end and stock crank.
Sincerely,
Jr.
Yep,,,,,,OMG 1000HP Yeah ur right and the stock injectors will be enuff too for $4-$500. 1000 hp for cheap..Oh yeah its so cheap I see them every day. Lets do the basic math..Injectors and fueling system and Hotside,Cold side and the little cheap budget Turbo itself,,,Intercooler and all the related clamps and fittings $$$$$$, Tuning it----U have a dyno In your garage==Great and then you must have a transmission and convertor or stout Manual and cheap clutch that can handle that much power along with a pile of other stuff to go with it. And them stock head gaskets and bolts can handle a ton of boost too right.....===WRONG. LOLOLOL TRy again.
Old Jan 29, 2014 | 07:25 AM
lemons12's Avatar
You got it all figured out man.. Ill contact you for our top dollar 1000hp builds for now on. Thanks for the info.
Old Jan 29, 2014 | 01:01 PM
R6cowboy's Avatar
Originally Posted by jim1450
Porting an LS6 intake is a waste, no gain.
Just curious, have you tested that before or know of someone who has?
Fast102 is perfectly fine for a h/c LS1 and will be fine running it before the heads and cam also.
Old Jan 29, 2014 | 06:07 PM
z28SSilvest's Avatar
I would say don't put the Fast 102 on the car until you have your cam and heads install. You're going to need (or it would be in your best interest to get) a tune JUST for the new intake manifold. I would say get your heads and cam combo down then get the Fast on there after everything has been installed.
Get it tuned once lol. I have over a thousand dollars on the dyno just for tuning which could've easily been avoided had I waited to install everything at once.
Old Jan 29, 2014 | 08:13 PM
metlic53's Avatar
Oh man ==just messing with ya. Its all good. No top-dollar builds for me.
Old Jan 30, 2014 | 03:03 PM
ckpitt55's Avatar
what rails are you guys having problems with?
I got the FAST LS2 style billet rails and FAST 36lber ls1 style injectors. Needed to use the included spacers and larger o-rings that came with it. For added insurance I also threw on the LS2 injector clips as well. Without them on, I noticed it's possible to seat the injectors into the rail at a position that some seem to think is too far and causes leaks. I actually had to lift the rail up off the injectors a bit to be able to install the clips. Might be something to check if you're running the billet style.
Old Jan 31, 2014 | 06:34 AM
R6cowboy's Avatar
I also agree with this guy ^^^
Old Jan 31, 2014 | 10:08 AM
Rise of the Phoenix's Avatar
So you can buy the FAST 102 with either the FAST ls1 or ls2 style rails?
Old Jan 31, 2014 | 11:55 AM
lemons12's Avatar
Either fast 102 specific rails or the ls2 style rails.
Old Jan 31, 2014 | 11:56 AM
JakeFusion's Avatar
Super Hulk Smash
I bought take-off LS2 rails from Scoggin Dickey. Same for the LS2 waterpump.
Don't know if they still have them... but they are pulled off the LS2 crate motors and sold pretty cheap. So brand new GM parts.
Old Jan 31, 2014 | 12:06 PM
Jake, would you mind PM'ing me everything I'll need to swap over to a 102/102 setup? I want to do like you did and use stock LS2 rails. I guess I'll also need adapters for my Accel injectors in order for them to be compatable with the LS2 rails.
Old Jan 31, 2014 | 03:07 PM
  #32
ckpitt55's Avatar
LS2 style rails only with the 102. LS1 rails have a different injector to injector spacing and don't fit the intake.
Old Jan 31, 2014 | 03:15 PM
  #33
JakeFusion's Avatar
Super Hulk Smash
Let me update this since I never saw this until I installed it:
You need to go buy about 24" of 1/2" hose for the brake booster (stock isn't long enough, because the nipple off the intake flares straight back and not off to the driver's side like GM or FAST 92). And you need to get a clip for the MAP sensor if you don't relocate to the front. Otherwise, it will hit the firewall and you have to turn it 180 degrees to fit, which makes the hold down screw in the wrong place. But a screw-down clip, like that used by an electrician to hold wiring up along drywall works. (And I don't recommend relocating to the front - you get better readings from the LS1 sensor in the rear.)
The FAST 92 is easier to install because it doesn't require new rails, a new WP (or grinding stock), and the brake booster vacuum line is angled back toward the brake booster (with the MAP on top - also a plus). Also, the 92mm TB is easier to tune from what I understand. But a good tuner should be able to make the 102 work. Of course, the 92 TB works on the 102... but only the FAST 92 and GM LS2 90 actually seal properly.
Nothing really that big of a deal. Just extra hassle you have to account for when you install the 102.
Old Jan 31, 2014 | 07:04 PM
  #34
lemons12's Avatar
I have stock brake booster hose.. Map sensor fits.. Ground stock water pump.. New style 102 supposedly fixed part throttle and response tuning.
I run the fast 102 tb no issue.
Old Feb 1, 2014 | 11:13 AM
  #35
Bolt-OnM3's Avatar
I have a fast 102 setup tb/mani/billet rails with arh 1 7/8 and I put 347 wheel down. No leaks btw. (Thru auto)
Old Feb 1, 2014 | 11:21 AM
  #36
JakeFusion's Avatar
Super Hulk Smash
I don't see how the brake hose fit... mine was at least 3" short before accounting for the extra inch or so that would be needed to route it coming in from the passenger side vs driver.
And the MAP sensor fits anyway you want on there... the problem is the wiring harness. When I plugged mine in, it was touching the firewall and was pushing the MAP crooked. That's bad juju with a hard rev. And I have Prothane motor mounts.
Old Feb 1, 2014 | 12:24 PM
  #37
Undertow74's Avatar
I had no problems with the brake booster hose. Fit just fine. Unless someone had put a different one on your car before at some point. And I ran the MAP sensor in the front so I didn't have to worry about jamming it into the fire wall
Old Feb 1, 2014 | 01:47 PM
  #38
lemons12's Avatar
I've never heard of anyone having an issue with the brake hose??
Map is tight but has room. I have had no problems and give the car hell often.
Old Feb 3, 2014 | 01:30 AM
  #39
JakeFusion's Avatar
Super Hulk Smash
Who knows. I put a new line on there.
Also, make sure you have some M6 nuts to secure the stock throttle cable bracket to the manifold. If the manifold came with those, I didn't see it (though I swapped to some zinc plated M6 bolts as well since the stock bolts were discolored).
