AIR block off plates
Old Jan 30, 2014 | 06:38 AM
'02 WS6's Avatar
Default AIR block off plates
If someone has some free time would you mind measuring your plates and providing the dimensions (height/width/distance between bolt holes/etc). I have some Pacesetters with this junk and figured I'd make some at work while the car is down. Thanks!
Old Jan 30, 2014 | 10:45 AM
10droped's Avatar
This should work for you all dim in mm and I think I made it 1/4"
Thick
Old Jan 30, 2014 | 10:52 AM
10droped's Avatar
And if anyone needs the EGR delete plate here it is
Old Jan 30, 2014 | 11:42 AM
'02 WS6's Avatar
Thanks man! I'm gonna see if one of the guys here can fab one up off that.
Old Jan 30, 2014 | 12:49 PM
99 Blue Bird's Avatar
Y don't you just go buy a 1'x1' piece of sheet metal and trace the gasket onto the sheet metal. Than cut it out with tin snips and use a bench grinder to clean up the edges. And your done. No need to make something so simple a complicated thing. It's pretty easy to do. Tookme about 15 min.
Old Jan 30, 2014 | 02:59 PM
'02 WS6's Avatar
In this instance simple is making them when I'm here and car is down at home. This way negates an additional trip to a store when all the utensils and tools are readily available and my disposal here.
Old Jan 30, 2014 | 04:28 PM
jimmyblue's Avatar
Moderator
I made mine by a pencil-rubbing from the AIR "spider" flanges,
and a bit of aluminum flat stock using hand / bench tools
(hacksaw, flat file, drill). Mild steel would do as well.
