Busted LS6 intake...fixable?
My father in law has a Seelye plastic welder. We called the company to see which rod we should use to try to fix it. They've never had anyone inquire about this application, so we sent them a junkyard intake plenum to experiment on. If they are successful, they'll send us the proper rod and we'll give it a shot.
If that doesn't work out, I'll try to epoxy over it.
Post #'s 10 and 11.
I used the Loctite plastic bonder acrylic based adhesive on my LS1 intake when I removed the MAP port from my intake. It's pretty cheap from Home Depot or Lowes, or Target, etc. It's working OK, but the operational temp is only 180F, which means the adhesive will probably be subject to higher temps than the max rating at some point.
If I were bonding an expensive component, I would use the Reltek Bondit45 or Bondit45TH. It is expensive but it works on PA66 material pretty well.
I got the info from the manufacturer (page 31 in the pdf and 177 on the document)
http://www.on-hand.com/Manuals/How%2...ndPlastics.pdf
Here are some pictures of my broken LS6 intake but I have all the pieces. I have $0 in it so its worth a try to fix.
Yes its very very dirty.
http://www.itwplexus.co.uk/images/uploads/tds/310.pdf
If I had found that before I bonded my intake I probably would have bought that instead of the 180F rated Loctite material. The extra $20 in price would have been worth it.
One could even use superglue (cyanoacrylate) but it would eventually fail due to temp and humidity.
The dirt is because it came from the desert and the seller had 26 of them on a shelf so I assume it had been sitting collecting dirt for a while.
I got the epoxy I ordered. If it works $30 will be a cheap price to pay. As a recap, this epoxy is listed by the manufacturer to bond to nylon 66 (what the intake is made of). Its the only epoxy I have found that says it can bond to the Nylon 66 thermoplastic material. It just can't fill large voids or holes, its for bonding and has to stay only a few millimeters thick. Anyway, this is just a spare intake that I have nothing in so I will try it out and report on the results.
My results will be slow since A)its been to cold to turn my outside water on so no pressure washer to clean the nasty intake and B) My swap won't be in a place to run until fall. I'll get around to doing the repair once it warms up. Worst case I'm out $30.
Here is a question for you guys though. The rear map port isn't designed to come out very easy and it has the o-ring for a seal. Could A guy just use the epoxy to bond the MAP port into the intake and ditch the oring. It would be just a more ridged mounting. I don't see a problem with it but I want opinions. Because of the way mine broke I'm concerned with the o-ring seal.
