Is this all I need for headers?
Old Feb 14, 2014 | 07:46 PM
Bill Smoke's Avatar
Came across this nice cheap set of headers on ws6store.com with free shipping to boot.
I only want long tubes on my car, dunno why people ever decided to get shortys or mid length.
http://www.ws6project.com/user_stor/...ystem-chrome-/
Is everything included in that? Says it has the harness, installation tools, headers, CONNECTING offroad y-pipe.
Am I missing anything?
Current mods to the car - SLP loudmouth 1 SLP lid, Ported and polished throttle body.
What's a local shop charge to install these usually? Also, you think I will need a tune after it's installed?
Also, what's the estimated horsepower gain from adding headers with my current setup? Think it will be too loud or raspy with longtubes?
Old Feb 14, 2014 | 07:51 PM
HCI2000SS's Avatar
You sure you want this combo lol? I had the LM1 with long tubes and ORY and it was retarded loud and raspy lol
Old Feb 14, 2014 | 07:54 PM
Bill Smoke's Avatar
Is it really that loud? Should I replace the LM1 resonator with something? If so, what?
Or, would it be quieter if I just got a hi-flow catted y-pipe instead? Looks like those are harder to come by.
Old Feb 14, 2014 | 08:02 PM
HCI2000SS's Avatar
Well what I did was replaced the LM1 with a Magnaflow 14419 (same dimentions as the LM1) then added a Flomaster merge to my Pacesetter ORY. Sounds MUCH better now lol!! Oh... and yes it really is that loud lol
Old Feb 14, 2014 | 08:11 PM
Bill Smoke's Avatar
do you have a sound clip of your car when it was just headers?
Old Feb 14, 2014 | 08:14 PM
HCI2000SS's Avatar
You mean with the LM1, ORY, and headers? If so yes I do, but I don't have one with the new setup yet
Old Feb 14, 2014 | 09:11 PM
Bill Smoke's Avatar
Ok cool. Can you link me to it? I'd like to hear it.
Old Feb 14, 2014 | 09:59 PM
HCI2000SS's Avatar
It's a really small idle and rev clip, but hopefully it will help a bit.
http://s560.photobucket.com/user/rab..._1686.mp4.html
Old Feb 15, 2014 | 10:03 PM
That_Z28_Camaro's Avatar
Music to my ears I demand a video of the new setup! lol
This is with LTs, ORY, and LM1...it's screaming loud lol..i blew my ears out in this video
http://youtu.be/RchdjwGLtIQ
And this is the current setup
http://youtu.be/3a_JvAN9rek
Old Feb 17, 2014 | 11:02 AM
demonspeed's Avatar
It's not mine! woo hoo!
I'd look at the Speed Engineering LT's. The BBK is nice, but their y-pipe is only 2.5" vs. Speed Engineering 3". Further, Speed Engineering are stainless.
I'd also suggest polyurethane motor mounts and new plugs while you're in there; also new wires if they've got some miles or look rough. While a tune is not "required," it'd certainly help make the most of the new exhaust. It will also remove codes for no converters, AIR, and EGR (if you're a 98-00).
Old Feb 18, 2014 | 06:34 PM
Bill Smoke's Avatar
What kinds of gains are you looking at for a 2.5 vs a 3? Wouldn't a larger y-pipe decrease low end torque? Stainless steel is nice though.
What's the advantage of polyurethane mounts? I heard some people say it makes the car ride too rough. I'm about to get the plugs and wires done, my car is overdue for that.
Old Feb 18, 2014 | 09:02 PM
slikrider20's Avatar
I've done about 3 header installs on these cars and BBK were by far the easiest to install. The hardest part of it is getting the old exhaust out. I'd spend a little more and at least get the ceramic coated ones.
I'd also pick up some GM MLS gaskets and o2 extensions, both of which are available on Ws6store.
Old Feb 19, 2014 | 11:45 AM
demonspeed's Avatar
While I do not know if anyone has provided empirical evidence to quantify 3" vs. 2.5" pipes, I can guarantee you'll be able to find many technical posts by searching the forum explaining inside diameters, where torque/hp is made, etc.
As for poly mounts, the factory rubber mounts sag and compress over time. This is generally the cause of any banging or rubbing of header primary tubes. Replacing the mounts ensures nothing is slopping around. Further, I noticed absolutely zero drivetrain vibration after adding poly mounts.
Old Feb 19, 2014 | 09:49 PM
Bill Smoke's Avatar
What is the advantage of going ceramic coated?
02 extensions are for the codes, right? I'll be getting those for sure.
Old Feb 19, 2014 | 10:41 PM
99Bluz28's Avatar
Keep in mind that the 2.5" pipes are NOT the first restriction, the 3" y-pipe exit and 3" cat-back exhaust is. So unless you going to use a larger y-pipe exit and a similarly sized cat-back with the 3" Y-pipe inlets you're still stuck with the same single 3" cat-back which is the first restriction. What that means is the 3" pipe vs. 2.5" pipe benefit is still minimal until the bottle neck is eliminated.
BTW, go with the poly motor mounts, they're worth the effort to install a set.
Old Feb 19, 2014 | 11:03 PM
Chrome doesn't hold up to the heat nearly as well, plus they'll turn into rainbow colors pretty soon. The ceramic coating will help keep the engine temp down considerably.
The o2 extensions are for the front o2's. The bunghole for the o2 is obviously a lot further back with longtubes.
You'll have to get the rear o2's deleted though. I think it costs $50-75 or so depending on where you go.
Old Feb 20, 2014 | 10:15 AM
demonspeed's Avatar
True.
I'm thinking, however, that for the cost between BBK and Speed Engineering, it makes sense to just go with the latter.
Old Feb 20, 2014 | 01:03 PM
99Bluz28's Avatar
Yeah, stainless steel headers are the way to go, especially back east with the high humidity and all the salt on the roads during the winter.
