What intake needed for 7500 rpm?
Old Feb 15, 2014 | 10:52 AM
zboy2012's Avatar
Default What intake needed for 7500 rpm?
Ok so I got a solid roller camshaft that is 255/260 .651/.651 on a 1111 llsa power is 3500-7500 is what I told by the guy I got my short block from (cam came with it) so my question is what intake would best for this? Thanks in advance.
Old Feb 15, 2014 | 10:54 AM
zboy2012's Avatar
It's going to be built motor for N/A application and going to have ported 243 heads by AI.
Old Feb 15, 2014 | 12:16 PM
BigDB's Avatar
Your avatar is of a LT car but Im gonna assume this is a LS engine and for drag as its a solid roller. A FAST would probably get the job done but defiantly leave some power on the table. Id say go with a Vic Jr ported or a Victor if you dont care for your windshield cowl. At the very least a 100mm MAF but speed density would really be the way to go for a drag setup. If you looking to put this is a street car Id suggest a hyd. cam and less cam plus a FAST just for packaging purposes and ease of maintenance.
Old Feb 15, 2014 | 12:31 PM
M.BOZZ's Avatar
I run a fast 102 intake, 248/260, 615-636 solid lift and 799 stage 3 heads on SD tune. My power range is almost the same as yours ( 3600-7200 )rpm I lost some power going to a SD tune but does good on the streets. If your looking for every bit of hp then go to the victor setup
Old Feb 15, 2014 | 12:49 PM
luigiandme's Avatar
I would definitely go with a single plane intake like a Super Victor with a 4150 TB.
Old Feb 15, 2014 | 01:24 PM
zboy2012's Avatar
See that is what I wanting to do is be able to drive it on the street a couple days a week and be at the track two weekends every month and I know people with Bigger cams that run around on the street around here lol
Old Feb 15, 2014 | 02:54 PM
sepsis's Avatar
What's done to the rotating assembly? (just curious)
Old Feb 15, 2014 | 03:18 PM
zboy2012's Avatar
Arp rod bolts, stock crank, Eagle rods, -4cc mahle Pistons and the cam
