Best stall converter to run
I'm running a th400 Trans behind a 5.3 with a stock lower end and head.
I'm putting a custom ground cam in it with an ls1 intake and twin turbos.
Cam specs:
ADV. DUR. 284 Int. - 289 Exh.
@050 224 Int. - 230Exh.
Lift .595 - .595
Lobe center 114
Centerline 110
T04E Turbo specs:
Compressor
3" inlet
50.55 inducer
57 trim
Turbine
T3 flange
.63 A/R
65.2 inducer
56.06 exducer
Cam specs:
Lift .595 - .595
Lobe center 114
Centerline 110
T04E Turbo specs:
Compressor
3" inlet
50.55 inducer
57 trim
Turbine
T3 flange
.63 A/R
65.2 inducer
56.06 exducer
