ls1 coolant temp reading newbie -39 help!!!!!!!
Only the coolant temp gauge on the dash requires the temp sensor to be grounded.
Russ Kemp
If after doing these additional checks & still an issue, it's likely the PCM.
mine reads -38 on the hp tuner new sensor new thermostat kind of baffledIt ended up being the male side of the temp sensor if anyone else has the same issue
