Rear Steam Tubes Fast 102
I purchased the 4 corner Trick Flow kit very disappointed with its fitiment.
Anyone have any pics of your setup on the Fast 102?
I've got a couple of things working I'll know more tomorrow evening.
I thought about the ( KUP ) kit however with the remaining bad taste that I still had in my mouth from the other kits that I bought, I decided to go this route.
Then we drilled and taped the opposite end 1/8" NPT. Purchased ( 4 ) 1/8" NPT x 1/4" tube compression end 45 degree fittings. If you have a fast 102 you will still have to grind the radius of the 45's a little bit on the passanger side rear and the drivers side front. I probablly could of machined the thickness down a little but decided to grind it down a little. You will have to play with everything a bit but it is doable, and looks good as well.
Also you will have to counter sink the bolt holes as well.
Good luck!!!
