LQ9 to T400 TC Question
Old May 31, 2014 | 04:52 PM
92ranga's Avatar
Default LQ9 to T400 TC Question
Just bolted up my 06 LQ9 to a T400. LQ9 has the dished flex plate so I installed the spacer on the outside of the flex plate. Torque converter is pushed all the way into the trans and there is approximately a 1/4" gap between the flex plate and the mating face of the torque convert bolt standoffs. It's been a while since I've bolted up a TC. Is this normal? Should I go ahead and bolt up the TC and suck it into the flex plate?
Thanks,
Mike
Old May 31, 2014 | 05:15 PM
LS1MCSS's Avatar
Use about an 1/8 inch spacer between them and go for it.
