Which brackets/pulleys for my swap
Old Jun 9, 2014 | 02:52 AM
LSXCLONE's Avatar
Default Which brackets/pulleys for my swap
SO, I have done quite a bit of research between a few different forums on what pulleys/brackets to run on my swap for my Syclone. Im going to be running a 5.3 truck block with ls6 top end. I need as much front end clearance as possible to clear the fans and rad, and a high mount alternator to clear the frame. I would really prefer to not use aftermarket brackets to keep the OEM look. my question is can i run a ls2 water pump/vette crank pulley and all other vette accesory brackets? or do i need to run fbody brackets?
Old Jun 9, 2014 | 06:04 AM
LS1MCSS's Avatar
If you want maximum front clearance, use all vette accessories.
