dual 2.5 or single 3.5 pros and cons
Old Jun 18, 2014 | 09:46 AM
chumscustoms's Avatar
Default dual 2.5 or single 3.5 pros and cons
I'm getting ready to fabricate all of my exhaust my question is am I going to have any power loss or anything negative by just running from long tube headers into a 2.5 to 3.5 y reducer. Going to go into a spintech. Motor is a 350 ramjet.
Any opinions would be great
Old Jun 18, 2014 | 02:14 PM
Siciliano15's Avatar
usually dual 2½" pipes are about equal to a single 3.75" pipe so by going from dual 2½ to single 3½ you arent really going to give up much if any power but it would obviously sound better but cost more and weigh more if you kept it dual 2½ all the way.
Old Jun 18, 2014 | 06:26 PM
99Bluz28's Avatar
Dual 2.5" pipes and a single 3.5" pipe flow almost the same. The dual 2.5" pipes do flow slightly better, and will sound a little better than a single 3.5" pipe but otherwise I don't see any noticeable power difference. One advantage running the single 3.5" pipe has is less overall weight since you'll be running only 1 muffler, not 2. So there also might a price advantage depending on muffler choice.
Old Jun 19, 2014 | 12:51 PM
Marc 85Z28's Avatar
Both of those choices are more than adequate for your Ramjet.
