header install help.
Old Jun 29, 2014 | 03:09 PM
sweetmongo's Avatar
Default header install help.
Working on installing pacesetter on the driver side and cannot get the steering shaft off. I have both bolts out and it won't budge, I've tried PB and dead blow too. Is this how it is supposed to come out? Is there another way to get the header up there? Can I grind off that tab on the motor?
Old Jun 30, 2014 | 03:11 PM
sscamaroburn02's Avatar
Is this going on a Camaro?
Old Jun 30, 2014 | 03:51 PM
Infantrymarine's Avatar
Any luck?
Old Jul 1, 2014 | 01:54 PM
demonspeed's Avatar
It's not mine! woo hoo!
There have been some instances where people have replaced the steering racks with rebuilt LT1 units thanks to unknowing parts countermen. They bolt right in; however, they mess up the alignment of the steering shaft.
Old Jul 8, 2014 | 07:04 AM
idle's Avatar
Not sure on the shaft but I had to grind down this little square corner off of my block to get my 1 7/8" TSP's to fit; 99 TA.
Old Jul 8, 2014 | 07:17 AM
Unertl42's Avatar
I ground the tab off of my motor. Just ensure that everything is covered that you don't want aluminum dust to get into.
