QTP Headers and Installation
Old May 20, 2004 | 01:13 PM
Blacker's Avatar
Default QTP Headers and Installation
QTP Header:
These headers are the best quality headers that I have ever seen. The welds are great and smoothed out inside the flange. The headers are made from 304 Stainless Steel with a wall thickness of 0.049”. The Hooker LT’s have the primary sticking through the flange, as the QTP’s do not. The flange is smooth on the head side and provides a better seal. When I removed the Hooker LT’s, I had a header leak on #6 and #7. The Hooker LT was torqued per spec and still had a small leak. The QTP's tuck up great and ground clearance is great, even with cats. The O2 bungs are on the inside of the header, they way they should be.
Installation:
The passenger side header slid right in without trouble. I used the Stage 8 bolt’s as well. The driver side is a tad more difficult. I removed the oil filter and drain plug. Then, the header slid up into place. The car was off the ground 20” and no problems in that area. These were easier to install than the Hooker LT’s I had before. Out of all of the LT’s I have installed, these were the easiest. The headers are pull closer to the engine giving a lot of clearance around steering shaft.
Y-Pipe Installation:
This came in 5 pieces. It looks intimidating but it really isn’t. I just started with the pieces that go onto each header collector. Rotating the piece to get the best clearance, progress to the next piece. The band clamp, that QTP provided, are strong. They are much better than the thin, stainless clamps that I used during the Hooker LT install. These clamps are narrower and very thick.
Gotta give QTP a big thumbs up for an outstanding product. When I ordered mine Barry was very helpful and the ETA was dead on. Great product and great customer service...................priceless in my book.
Here are some pics:
Old May 20, 2004 | 01:18 PM
foff667's Avatar
LS1TECH Sponsor
look pretty good, glad they worked out for ya
Old May 20, 2004 | 01:27 PM
gomer's Avatar
Did you have to disconnect the steering shaft to install the drivers side?
Old May 20, 2004 | 01:40 PM
Blacker's Avatar
No, just the oil filter and drain plug.
Old May 20, 2004 | 01:46 PM
Scalpel's Avatar
Those are the exact ones I want, with the race collectors
Old May 20, 2004 | 01:53 PM
mrhawk's Avatar
I think i am going to end up buying a set to QTP's
Old May 20, 2004 | 02:32 PM
Blacker's Avatar
Sounds like a good decision
Old May 20, 2004 | 02:49 PM
jsm00z28ss's Avatar
I have them on my car as well. They are just a great header. When mine were installed there was not a single problem. The passanger side went right up and the driver side just needed to be turned just so and then it went right up as well. I can not say enough great things about them as well.
 Michael S. Palmer
Old May 20, 2004 | 04:02 PM
LS1LT1's Avatar
Thumbs up
I don't think those are the ones with the optional high velocity merge collectors, they look like the standard (and still awesome) QTP LTs to me, maybe not.
Great choice in headers either way.
Old May 20, 2004 | 04:16 PM
ZigZagZ's Avatar
The labelling on the tubes (Rath...) are exactly the same as those on my set of Kooks headers. QTP must purchase their stock from the same supplier.
Old May 20, 2004 | 08:50 PM
cm02WS6's Avatar
Yeah, they look exactly like my Kook's. They are both based off of the Grot design. If I get to do my project car, I will be going with QTP's though to try something different.
Old May 20, 2004 | 09:11 PM
Blacker's Avatar
Great choice in headers in either way.
I just got the standard merge collector. The HVC's was +$500 and I was not up for that.
Old May 20, 2004 | 09:35 PM
Durien's Avatar
i have the QTP High velocity headers..they are a great product
Old May 20, 2004 | 09:58 PM
1BADFNZ's Avatar
hey have you got a pic of the drivers side ypipe?? Well if it's the catted y pipe anyway I want to see If i got mine too low.
Old May 20, 2004 | 10:15 PM
Go FasTA's Avatar
Those look very nice!
Old May 21, 2004 | 05:40 AM
99huggerorangeZ's Avatar
those are really a nice set of headers as soon as i get enough money saved up i am going to be going with those headers and the QTP ORypipe with the dual electric QTPs
do you have any pics of the ypipe?
Old May 21, 2004 | 07:22 AM
travisnd's Avatar
I've got the regular longtubes and catted y from QTP. I have yet to get it dynoed, but I am shortly.
Old May 21, 2004 | 07:47 AM
2ScoopsTa's Avatar
those are the same ones i just got.. thats a great writeup!
i installed mine a few weeks ago with the help of my father.
they are great headers
Old May 21, 2004 | 12:04 PM
JL ws-6's Avatar
Race your car!
I just had mine installed, headers I can't say enough about, they are great. Y pipe, that's another story. If you have a spohn torque arm, be prepared to do some serious re-fabricating. Of the 12 hours that it took for the install, 8 of it was on the y pipe.
Old May 21, 2004 | 01:05 PM
Blacker's Avatar
