Solid Motor Mount Issues
Old Jul 20, 2014 | 07:10 PM
NVUSZ28's Avatar
Default Solid Motor Mount Issues
I'm installing Spohn Solid Motor Mounts on my '01 T/A M6. I've jacked the motor up as high as it could go. I've removed the Alternator, Alternator bracket, and still cannot get the **** in.I've even unbolted the passenger side motor mount to get the motor as high as it can go. I've loosened the 6 bolts on the K member, and I'm about to unbolt the shocks from the towers to lower the whole K member down.
Seriously though, has ANY one had this much trouble getting in these mounts? I'm getting pissed!
Old Jul 21, 2014 | 10:33 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Not problems like that. I ran them as well. I started the bolts only a few turns till I had them all in, then torqued them all down. I fought it for a bit, but it worked.
Old Jul 22, 2014 | 10:06 AM
skiziFiziks's Avatar
Are you doing one side at a time or both at once?
Old Jul 22, 2014 | 05:49 PM
NVUSZ28's Avatar
One side at a time. I'm about to unbolt the shocks and drop the K member. If I do that, then I'm unbolting everything and suspending the motor.
Old Jul 22, 2014 | 08:42 PM
dr_whigham's Avatar
The Scammer Hammer
Dude, no. Stop. You'll NEVER get them in one side at a time.
Unbolt them BOTH from the k member side, even leaving the plate to motor bolts a bit loose.
Now, LOOSEN the Trans mount. Trust me. It will work. You're fighting the Trans mount and a whole other motor mount.
Do this, and report back tomorrow with your success.
Old Jul 23, 2014 | 10:14 AM
01ssreda4's Avatar
Make sure the trans is straight in the tunnel before tightening everything up (if the trans mount is loose). I didn't keep an eye on it and had to go back and straighten it.
Old Jul 23, 2014 | 03:39 PM
NVUSZ28's Avatar
I didn't think of that, but when I loosen the trans mount, I am not taking out the bolts completely, correct?
Old Jul 23, 2014 | 03:51 PM
dr_whigham's Avatar
The Scammer Hammer
Correct. It should be just a nut. I haven't had a stock Trans mount in YEARS, so I'm going off what my Prothane was.
Old Jul 24, 2014 | 10:00 PM
NVUSZ28's Avatar
Well I didn't have to loosen the Trans Mount, I just lowered the K Member about 1 more inch, and Wha Lah!
Now I have stock motor mounts for sale! Someone make an offer, LOL!
Old Jul 25, 2014 | 12:46 AM
dr_whigham's Avatar
The Scammer Hammer
Glad to see you got it all sorted!
Old Jul 25, 2014 | 11:44 AM
Majestic9C1's Avatar
I was under the impression that if one switches to solid motor mounts the fillings in your teeth will rattle out and make driving unbearable
Old Jul 25, 2014 | 02:29 PM
dr_whigham's Avatar
The Scammer Hammer
Haha... No no. Honestly, I didn't really feel a difference at all, but man it sure seems to make it more responsive, bc you aren't loosing ANYTHING to MM flex
Old Jul 25, 2014 | 04:04 PM
NVUSZ28's Avatar
No, I have such a large cam in the car, that now, it feels about the same in the car, but the motor isn't doing any uncontrollable shaking at all!
Old Jul 25, 2014 | 10:54 PM
64post's Avatar
All three need to be solid? or, can you retain the rubber mounted trans mount? This is an issue on some cars
Old Jul 26, 2014 | 12:52 AM
dr_whigham's Avatar
The Scammer Hammer
I don't recommend Energy Suspension trans mounts. They aren't perfect, and you have to toss the preload plate right off the bat. Go with the Prothane.
I would never go solid trans mount. Ever
