crossover steam line help
Old Jul 27, 2014 | 09:48 AM
mikesimpalass's Avatar
Default crossover steam line help
Hi, my engine originally came with the steam pipe that only vents the front of the engine, and it has the rear Ports blocked off. I would like to find the style that vents all 4 steam Ports. Does anyone know the GM part number for these? I would like to find the truck style, but if nothing else I can use the original ls1 style.
Old Jul 27, 2014 | 11:00 AM
conan's Avatar
Here's what I did with my steam ports this time around... The rear crossover tube is from a cadillac, GM part #12605716. The front cross over tube is from the ls6, Witch you have already.
Here's the rear cadillac crossover...
Here in the green square is the front ls6 crossover...
Old Jul 27, 2014 | 11:46 AM
Wow, your engine looks really good. You do nice work.
That looks really good, but i would luke to find
Old Jul 27, 2014 | 11:47 AM
That looks really good, but i would like to find the one peice truck style since i have the.room under my intake for it.
Old Jul 27, 2014 | 11:48 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
So where did that little barbed fitting come from? That actually looks like a GM part. The one in the front...
Old Jul 27, 2014 | 02:45 PM
conan's Avatar
Thanks for the complement, What intake manifold are you running. You could try to find a used pipe from a 98-00 f-body that had a ls1 intake. Its a pipe system that fits under the intake. Here is what my car had originally...
https://www.google.com/search?q=ls1+...2F%3B800%3B600
http://www.chicompany.net/index.php?...ndex&cPath=287
Old Jul 27, 2014 | 02:54 PM
Majestic9C1's Avatar
I think I may do that setup to mine as well
Old Jul 27, 2014 | 05:41 PM
IM using an 04 dbw truck intake, I figured it would be easy to find these on ebay, but no such luck
