SES Light after Header Install...
Old May 23, 2004 | 07:40 PM
NOZR1's Avatar
Originally Posted by Camaro SS 2002
Excuse my IGNORANCE, but im still confused. I'm going to have Kook's LT's and their catted Y installed in a few days. I was told all I need is o2 extensions. I won't get an SES light will I? Again, don't flame me, im just trying to understand.
With Kooks you will be fine with just extensions for the front. You won't get the SES light unless you forget to plug in one of the rear O2's like I did. BTW, the driver side rear O2 is a PITA to plug in because its pretty far up.
Old May 23, 2004 | 08:26 PM
jrp's Avatar
jrp
SN95 Director
jrp...I went outside this morning and looked at my stock manifolds. It looks to me as though there is some type of metal AIR restrictor plates in place already from the factory.Is the stock hole drilled to big? Or am I seeing something that doesn't exist? Thanks man, you've been a big help to me.
what your looking at is probably the stock air gasket, not a restrictor plate. the stock air gaskets have the hole diameter the same as the air tubes.
Old May 23, 2004 | 08:28 PM
jrp's Avatar
jrp
SN95 Director
Originally Posted by SouthFL.02.SS
Some y-pipes, SLP to name one, have rear 02 bungs.
As for the SES light, it kinda grows on you after a while. You seem to mind it less and less as your mod list increases.
you refering to the SLP oem replacement Y? if i recall the jet hot y also has the o2 bungs for the rears as well.
and your right, the SES light does grow on you , i got mine for the !egr and rear o2 sensors. still havent edited the codes out.
