Dime-size hole in ARH 1 7/8 primary - what?!
its honestly a nice gesture but i think it would honestly be cheaper to just get it repaired locally. on a side not why not just delete the air and egr and have the holes welded shut? I know you live in cali but I think the emissions thing went out the window went you went to lt's anyway
I've been tempted to delete the emissions equipment since it is indeed pointless now, but have kept it in case of a smog referee referral ticket, which would require me to revert everything back to stock for their hair-splittingly thorough inspection. I'd rather just keep the equipment on than rip it out now and have to reinstall later.
Look at the picture. Where it broke off is completely smooth and aside from discoloration from heat shows no signs a weld was ever there.
I agree it is a high stress point which does explain why the weld broke loose, but if the weld had proper penetration into the material it probably wouldn't have and it certainly wouldn't have sheered the whole bead off the header tube.
Closed ex-Sponsor Account
Regardless of use of blockoff plates or not, we will gladly fix the primary and can also help in finding a local ARH dealer that may be able to handle the task quicker.
PM sent, what phone # can we reach you at?
PM replied Steve. That information was via email with Nick, who at the same time offered the repair. I very much appreciate the concern and response by ARH, and I agree that blockoff plates (installed by a previous owner of the headers) are likely the cause of gradual weakening due to harmonics.
Not trying to start a pissing match just stating my opinion from what i can see in the pictures.
I have disagree looking at the picture the hole looks like it lines up perfectly with the bottom toe of the weld, so part of the header tube is likely still connected to the weld. It looks like vibrations work hardened the base material causing it to fail.
#34
First time I called a tow truck because I thought the motor was blown. The second time I just limped the car home, made a temporary patch to cover it and got it to a muffler shop that welded them up on the car.
