WTF?? New Pacesetter Y same diameter as I pipe???
"WTF?? New Pacesetter Y same diameter as I pipe???"
http://www.texas-speed.com/images/newPacesetter3.jpg
This is from TSP post in the sponsor forum. My y pipe looks like that. If you look at the "I", it appears to be 2 7/8 tubing. The side that is connected to the y pipe has been expanded. the section in the middle, appears untouched. And the outlet that goes to the exhaust, looks like it has been compressed.
I don't have calipers, the outlet of mine measures, 2 13/16 (OD).
I am wondering if you ypipe looks the same, or maybe they forgot to "compress" that section on some y pipes. I know someone else has installed this new y pipe and they said it went on easily?
DEE
The Y does not bang at ALL for Hourang.
We didn't have to losen the steering shaft, we just grinded the tab on the block down
The bolt tab buttet right up to the heat shield bolt perfect, we didnt use it tho.
I think your problem with the Y is where it merges the left and right parts together, that has to go in pretty far, if it doesnt go in all the way, it will cause some banging.
-Steve
When we did the Y and headers on my 99 we didn't have this problem at all. So a little warning to you 98 guys going with the Pacesetter new Y, make sure it's the right diameter before starting or get a pipe expander.
/rant off/
sucks
-Steve
