243 Head Milling
Old Sep 22, 2014 | 12:03 PM
hcb1700's Avatar
Default 243 Head Milling
Guys,
I am in need of helping deciding what heads to drop on an LM7 engine that I just got. I was reading that slapping a set of 243 heads on the LM& would drop the compression a bit. I am being offered a set of 243's, and know that these heads flow pretty well, at a very reasonable price.
Questions:
I read that you could have them milled .035", but would this affect the mating surface of the intake manifold, or anything else?
I am thinking about going with a TXS 233/239 cam or MS3 cam, so the stock heads wouldn't be good for this, right?
Thanks in advance!
Old Sep 22, 2014 | 12:30 PM
01ssreda4's Avatar
Ms3 and any milling may not like each other. 243s will drop a little compression over a stock 806 or whatever 5.3 head but will flow a hell of a lot better.
Old Sep 22, 2014 | 03:06 PM
hcb1700's Avatar
Do you think the 233/239 cam will work? Other then that, the intake will sit fine right?
Old Sep 22, 2014 | 10:15 PM
01ssreda4's Avatar
Yes, it will work but those are big cams for a 5.3.
Old Sep 23, 2014 | 10:27 AM
American Psycho's Avatar
I wouldn't put a cam that large in a 5.3l engine. I would stick to something in the lower 220s duration range.
Old Sep 24, 2014 | 01:06 PM
hcb1700's Avatar
Thanks for the advise you guys! After reading these comments, I have now started doing more research and looking for a smaller cam. Any suggestions, as to which cams you guys recommend?
Old Oct 17, 2014 | 09:20 AM
spent21's Avatar
go over to performance truck forum and search for 'baby cam'. there are tons of suggestions... my suggestion would be not to take anything as gospel from the internet, and to have some conversations with some reputable cam folks about how you want this engine to run, what your mods are, and what you want to do with the vehicle so that they can spec you a cam. if you're honest with yourself & do that, you'll be happier with the end result than if you took my word that a buddy has a 236/239 .625 on 110 in his truck that is totally streetable. with that being said, i have a 216/223 .601/.604 on 115 in my 5.3 truck and like it. if i had it to do over, i think i would have had PatG spec me one.
cam selection also depends on what the 5.3 is in. it makes a difference if you're putting it into a heavy *** truck vs an f-body.
as for the heads, check to see if they have the hollow valve stems or not. it makes a difference, and they're more expensive unless the guy doesn't know what he has.
'It takes .007" milling to remove 1cc from an LS1 head '
now i have heard that 0.030" is the limit on milling heads before you get into intake fitment issues. i can't speak from experience.
here is a run down of Ls heads that is on here somewhere (i have this saved and go back to it regularly):
LS heads:
933 97 aluminum perimeter bolt 5.7
806 97-98 aluminum perimeter bolt 5.7
853 99-00 aluminum center bolt 5.7
241 01-03 aluminum center bolt 5.7 (some late MY00 cars got 241 castings)
243 04 up LS6 aluminum center bolt 5.7 ***These castings were also used around 05 in truck applications***
862 99 and up 4.8-5.3 Truck heads
706 99 and up 4.8-5.3 Truck heads
799 05 and up 4.8-5.3Truck heads ***reportedly came on a few corvette's too*** These are basically 243 Heads
873 99-00 LQ4 6.0 Iron center bolt heads
317 01 and up LQ4 and LQ9 6.0 aluminum center bolt heads
035 01 - 04 LQ9 6.0 aluminum center bolt heads
Even more detailed info:
Casting Numbers 241, 806, 853
Head: 1997+ LS1 5.7 Liter Passenger Car
Material: Aluminimum
Part Number:
12559806 (1997-98) Chambers = 69cc
12559853 (1999-00)
12564241 (2000-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers
Chamber 66.67 cc------0.100--0.200---0.300---0.400---0.500---0.550--0.600
Intake 200 cc------------67----122-----178-----215-----219-----223---227
Exhaust 70 cc------------52-----97-----133-----156-----170-----76----180
What you need to know:
The standard issue LS1 heads is best all-around head for the street / strip engines . A thorough porting and millimg job plus a valve upgrade on these will really wake up your engine.The heads have undergone only minor revisions since their introduction in 1997 , most notably a switch from perimeter to center valvcover bolt configuration for the 1999 model year. Each style has its own dedicated valvecovers and coilpacks mounting apparatus.
Casting Number 243
Head: 2001 LS6 5.7 Liter Passenger Car
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Chamber 64.45 cc-------0.100---0.200--0.300--0.400---0.500---0.550---0.600
Intake 210 cc------------62------126----184----224-----251----256----257
Exhaust 75 cc------------57------108----143----163-----176----180----183
The LS6 cylinder heads is essentially a tuned-up version of the LS1 head. At 65cc, the combustion chamber is slightly smaller and more efficient than the LS1. The more efficient design shortens burn times and ultimately means less ignition timing advance is required to produce the same power. And because less timing allows more efficient combustion, the Ls6 heads allow the engine to produce more torque. The exhaust port is a unique D-shape that improves flow. LS6 heads are the best choice only when all-out power is needed. Be prepared for a big price tag at the dealer or steep core charge from your head porter.
Casting Number 706 and 862
Head: 1999+ 4.8L / 5.3 Liter Truck
Part Number:
12559862
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Valve Diameter: 1.89 inches
Chamber 61.15 cc----0.100--0.200--0.300-- 0.400--0.500---0.550---0.600
Intake 200 cc----------63 ---128----179-----210----218----221-----226
Exhaust 70 cc----------54 -- 93 ----121----145-----163----168----174
These small combustion chamber truck heads offer no advantage over an LS1 head except the smaller combustion chamber. This along with milling of the deck surface will allow a slightly higher compression ratio to be achieved. Because of the smaller intake valve installed in these heads a valve upgrade is practically mandatory.
Casting Number 873
Head: 1999-2000 LQ4 6.0 Liter Truck
Material: ***Cast Iron***
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Casting Number 317, 035
Head: 2001+ LQ4 and LQ9 6.0 Liter Truck
Part Number:
12562317 -LQ4
12572317 -LQ9
12572035 -LQ9
Compression Ratio: 10:1 LQ9 Flat top pistons
Compression Ratio: 9.6:1 LQ4 Dish piston
Chamber 71.06cc----0.100---0.200--0.300--0.400--0.500--0.550--0.600
Intake 210cc-----------66-----142-----196---228----236---238-----240
Exhaust 75cc----------59-----104-----137---155----167---173-----177
The LQ4 head received aluminum heads starting in models year 2001. All other features are the same as previous years iron heads. This is the workhorse head for street / strip turbo and blower cars. They offer a large combustion chamber that lowers compression ratio making them perfect for a forced induction application. Swapping on the LQ4 head drops the compression ratio of a typical LS1 engine to 9:5.1
The Cast-iron casting are heavy!
So you want to figure out how much to mill:
It takes about .005" milling of the block deck to remove 1cc of volume. It takes .007" milling to remove 1cc from an LS1 head
Simple Milling Math:
You have a stock 66cc chamber and you want to get down to 63cc
66-63 = 3. You have to remove 3cc's
.007 x 3 = .021. So to get your 66cc chambers down to 63cc you'd have to mill ~.021.
You can also do the reverse, say you want to mill a head .030 to figure out how many CC's that removes you take .030 / .007 = ~ 4.28. Milling a stock 5.7 head .030 puts your chamber at ~ 62.
241 cast heads were Die Cast which is a process that smooths up the ports a bit compared to the Sand Cast procedure that was done on the 806 and 853 heads. Once ported any "advantage" the 241 cast had is moot.
Same Info applies to the:
4.8L/5.3L Truck 862 and 706 Head castings
While the 706 Heads are a SPM = Semi Permanent-mold And considerd to be a more consistant head casting then the 862 wich are Sand cast, Once ported There Is no difference.
799 Vs. 243 Info Copied From pillboxesghost Post's in ths thread https://ls1tech.com/forums/conver...l#post10241473
This appears to be one of the common misconceptions about heads having the 243 casting no. -- they are not necessarily LS6 head assemblies. The LS2 heads (243 or 799 casting) have the "heavy" standard LS1 valves. However, they do have the LS6 springs.
Only the true LS6 engine heads have stainless steel (not titanium) hollow stem valves (the exhaust stems are sodium filled). These valves are slightly longer than LS1 valves too.
The LS7 heads do have titanium valves.
New LS2 heads are about half the price of new LS6 heads (check sdparts.com). GM is "really proud" of those hollow stem valves!
Oh, if you have the 799 castings -- the only thing "Corvette" about them is the valve springs/retainers! Still a desirable set of LS1 heads though!
Supposedly, the 243 mold was done at GM Research, the 799 mold furnished to other vendors. The same vendor may have the 243 and 799 mold.
Both heads have identical sized intake and exhaust valves
Old Nov 2, 2014 | 11:29 PM
hcb1700's Avatar
Spent21, great information here. Thank you for all of the help you have provided me with. I have left the cam decision for last, and will definitely be contacting some of the vendors on here when I'm ready to choose a cam. I have heard great things about Pat, and he will definitely be getting a call from me.
Old Nov 5, 2014 | 07:20 PM
1FastBrick's Avatar
FYI, You copied the head info from the performance trucks side.
GM head casting info
Old Nov 6, 2014 | 12:11 PM
spent21's Avatar
I remembered reading it a long time ago, and when it became relevant to my situation, i had trouble finding it... so when i did find it, i copied it into a word file, and i haven't had to look for it again. it's very useful... wasn't trying to plagiarize or lift your info.
Old Nov 6, 2014 | 02:11 PM
hcb1700's Avatar
I've done the same thing. Very good info.
