Ls 6 intake cracked!
Old Oct 2, 2014 | 08:28 PM
The Plastic Lizard's Avatar
Default Ls 6 intake cracked!
So I have a c4 with an ls6 I recently swapped. I haven't driven it out of my neighborhood until today. That's because I didn't have an exhaust and was just running open.
Today I went to get the pipes installed and after about 6 miles of very loud, but gentle running....it got very rough.
I was hoping that it was just not enough back pressure was messing up the o2s. But it turns out I had a crack behind the throttle body
1. Which is chicken, which is egg? The crack or the rough running?
2. Was this most likely cracked when I got it 6 months ago, and I just didn't notice until it heated up?
3. Anything else to check?
4. Can I just solvent weld this, or is the intake toast?
Old Oct 2, 2014 | 08:57 PM
Zmg00camaross's Avatar
intake cracked and caused vacuum leak and rough running. No idea if it was pre or post install. I would say you definetly could seal it up. Jb weld or some kind of epoxy.
Old Oct 2, 2014 | 08:59 PM
N20zuki's Avatar
I would stop drill the cracks and then epoxy it, As long as you don't mind it being ugly looking.
Did you get the motor from a wrecked car?
Old Oct 2, 2014 | 09:02 PM
Yes. Rearended c5
Old Oct 2, 2014 | 10:37 PM
redbird555's Avatar
I would drill it then look for epoxy that BONDS to Nylon 66 which is what he intake is made from. Theres a link somewhere on here in a diy thread for fixing one its 25 bucks a tube but the fact is ts the only thing made to bond to that type of plastic. You could plastic weld it but you would need a peice of scrap from another ls intake
Old Oct 3, 2014 | 09:08 AM
garys 68's Avatar
There are a couple threads on plastic welding nylon 66, including a video here. Probably best bet, followed by epoxy. I always drill the end of cracks to prevent them from starting again.
Old Oct 3, 2014 | 10:59 AM
jlcustomz's Avatar
You can get nylon 66 black tie straps from harbor freight & many places. Not 30 percent glass filled like the intake, but still suitable for welding .
Donor engine likely got hit in front OR manifold separately took a hit it wasn't designed to take. cracked didn't likely happen on it's own. Rear vacuum connection is another fragile area.
Old Oct 3, 2014 | 11:30 AM
SS Rider'z's Avatar
I recently repaired mine by plastic welding it with a butane soldering iron pen.. gets real hot melt the crack fill with nylon zip ties & cover with epoxy.. Mine was much worse, on the rear map sensor spot whole thing broke off.. Its good now..
Old Oct 4, 2014 | 04:16 PM
JS30612008's Avatar
Plastic welding will do the trick. Just prep it correctly might be ugly but it works
Old Oct 4, 2014 | 05:14 PM
LilJayV10's Avatar
This is what I used to fix my broken LS1 intake. Stuff is freakin amazing.
http://www.rapid-fix.com/
