Distributor on 6.0
Old Oct 7, 2014 | 09:51 AM
TrippyJoey's Avatar
Default Distributor on 6.0
So I'm thinking on maybe using my spare 6.0 longblock on my project but it needs to run a modified Ford/GM hybrid distributor so it can work and allow me to tune the ignition.
What are you all's experience with the GMPP distributor kit?
Old Oct 7, 2014 | 10:24 AM
KCS's Avatar
KCS
Moderator
They're good. They require quite a bit of clearancing if you run a double roller timing set though.
Old Oct 7, 2014 | 10:26 AM
TrippyJoey's Avatar
I won't be running a double roller, anything else? Also is GMPP the only maker of these?
Old Oct 7, 2014 | 01:55 PM
Fry_'s Avatar
It would probably be cheaper and easier to just run a MSD 6LS controller and stock coils.
Old Oct 7, 2014 | 02:21 PM
thunderstruck507's Avatar
Old Oct 8, 2014 | 03:56 PM
TrippyJoey's Avatar
I know that but my application requires an ignition module that works with distributors. It wouldn't work well with the msd 6ls
Old Oct 8, 2014 | 04:03 PM
KCS's Avatar
KCS
Moderator
As far as I know, yeah, GMPP is it. They're easy to install. They have a provision for a mechanical fuel pump too, but I can't remember if they come with a block off or not.
I don't remember what the gear is made if either so you may want to check to see what material your distributor gear will need to be.
