POTZ tb getting stuck at WOT...Advice
Could you show where in the pics that I supplied? You're speaking about the bump/throttle stop that was shaved off some? Can you confirm that if the blade is going past 90 degrees that it typically would be causing the throttle to get stuck?
In the end, the car is being stored this Winter as usual and if I cannot figure it out by Spring then I will get an aftermarket one when I cam it.
I've see it happen on a ported throttle I was cleaning. See if it sticks when you pull outward or push inward on the throttle cam. I bet that blade is just slightly off center. It doesn't take much.
