Which Spark Plugs
Old Dec 1, 2014 | 09:35 AM
RENE'S RAGE's Avatar
Default Which Spark Plugs
Bone stock '98 Vette, 100,000 miles.
NGK TR 5 or NGK TR 55. And what gap.
Been so long since I missed with a stock LS1.
Thanks!
Old Dec 1, 2014 | 10:59 AM
01ssreda4's Avatar
How often do you want to change them? If often is no big deal I like copper tips, gapped anywhere from 40-50.....but for a driver id take the OEM equivalent platinum tip. They are pregapped and should last 100k.
Old Dec 1, 2014 | 11:13 AM
Hell, I've never change them before. This is the old lady's car. I don't even sit in it, more less than work on it.
But I just got through putting a balancer on it. Pain in the ***!
Old Dec 1, 2014 | 09:43 PM
Russ K's Avatar
The TR5 is the correct plug, gap to .040. The TR55 is no longer correct for the LS motors as it's designed for a .060 gap. Gm has a TSB about a different plug that uses a .040 gap.
Russ Kemp
Old Dec 1, 2014 | 09:48 PM
HUMBL57's Avatar
If it's not a high performance application why not just go back with OEM ACDelco plugs? Cheaper and lasted you 100k miles so far
Old Dec 2, 2014 | 07:41 AM
01ssreda4's Avatar
A copper tipped plug was never right for any Gen2,3,4,5 engine sorry. OEM has been speccing iridium and platinum tipped plugs for decades. Why we've adopted the old habit of wanting copper tips I haven't figured out yet. I'm running OEM equivalent AC delco in my DD 6.0 Yukon, my previous STS, the old ladys SUV etc. I only run copper on the camaro and I don't have a ******* clue why!
Old Dec 2, 2014 | 08:34 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I still run TR55's gapped at... .055
Compression and HP will matter though. Old Camaro in sig had TR6's at .040 .045, can't remember.
Old Dec 2, 2014 | 09:39 AM
I had already bought the TR5's before I posted.
Guest I'll just gap them at .040 and let the band play Dixie!
