99 Trans am engine options
I'm not looking for any crazy hp numbers this was going to be a street car looking for around 600 or so on a m6.
I went with an LQ9 and swapped it in. If I could do it again, I would probably do things a bit different.
The LQ9 cost about $1000 to my door, a 383 rotating assembly would have cost me about $2000 to my door. I think, if I had to do it again, I might have gone with rebuilding the LS1 and building a stroker.
Now, considering you probably can't do that... I'd still at least rip apart that iron block and put in some better rods, pistons, etc.
I am a little on the fence still about what to do with the 6.0 block that I have. Right now I have a bare block but have the rods pistions and crank sitting off to the side. I already have a set of 317 heads in the shop getting a mild port job done and a turbo ll cam because I was going to turbo the ls1. I hate to build a stock bottom end and then blow it apart with boost down the road but don't know if it is worth getting high dollar rods and pistons. The plans for the car is to be a street car with around 600 to the wheels. I think more then that might be a little overkill for the street...
