LS6 vs BBK intake
I can tell you from experience on the 102 that the bellmouths have very sharp angles that can be rolled over and smoothed, then the runnerand port need to be opened up to have a smooth flow from the main runner part
If you really want the FAST in that CL ad and the guy says he mimicked Mamo, you should have the guy send pics of the FAST and ask Tony what he thinks. He'll give you an honest opinion. Hope this helps.
The CBM is tapered(small to larger) so there less air flow turbulence, which means better flow into (and through)the intake manifold.
Last edited by 99Bluz28; Dec 13, 2014 at 11:26 PM. Reason: remove incorrect info !
https://ls1tech.com/forums/ls1-domes...t-1715923.html
