Rear cover alignment
Old Dec 16, 2014 | 08:19 PM
kpayne8980's Avatar
Default Rear cover alignment
Need some advise on my measurements I took. Oil pan is off on my ls1 and my trans is removed. I'm installing a rpm lv5 4l60e. So while the trans is out I'm changing the rear main seal and cover gasket. From what
My Manuel says the cover can't stick past the bottom of block more than .020" my readings are flush on driver side and +.008" on passenger side. This is the first time I do this would you guys proceed on putting the pan on the motor?
Old Dec 16, 2014 | 11:38 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Hang the cover with the seal on the crank. Now it can rotate on the crank. Rotate it so both bottom edges are equal to the oil pan rail. Tighten the cover bolts.
A little Ultra Blue at these spots and bolt up the pan.
Old Dec 17, 2014 | 11:38 AM
01ssreda4's Avatar
This is exactly how you do it. Let the seal center itself or it will leak! Equal portions on the bottom (get it square) and you're good
Old Dec 18, 2014 | 06:36 AM
kpayne8980's Avatar
I used the sac city corvette alinement tool when installing the cover. It's pretty square I double checked it last night I feel good about putting oil pan on. I'll give you an update when I finish.
Old Dec 18, 2014 | 09:46 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Bingo. Let it center itself, hand thread / tighten the bolts, then torque in sequence. Easy peasy.
Except I used RTV Ultra Black and not the blue stuff Paul mentioned.
Old Dec 18, 2014 | 12:33 PM
kpayne8980's Avatar
Ultra black is what I'm using.
