98 LS1 pcv info and ideas
Old Dec 22, 2014 | 06:49 PM
unioncarpenter84's Avatar
Default 98 LS1 pcv info and ideas
i have a 98 ls1 what can be done to redo my pcv system its all dryrotted whats ur ideas on what to do
any advice
Old Dec 23, 2014 | 08:31 AM
bbond105's Avatar
Install a LS6 valley cover and two short hoses would be cheaper than buying all those LS1 PVC hoses from GM. See this site for more info. http://ls1howto.com/index.php?article=18
Old Dec 23, 2014 | 07:34 PM
Paul Bell's Avatar
That's MISTER MODERATOR
^ THAT. It's a way better PCV system.
Old Dec 23, 2014 | 08:26 PM
i agree but dont wanna cut into my block to make it work
Old Dec 23, 2014 | 08:29 PM
bbond105's Avatar
Then GM sells all the hoses. IIRC they are close to $130.
Old Dec 23, 2014 | 08:54 PM
HUMBL57's Avatar
Mine was the same case all cracked and brittle. Everything crumbled coming away from throttle body and then back near drivers rear valve cover. I was able to redo it all with supplies from Autozone and get by with some 3/8" hose, a 90* pcv fitting for the top of the valve in rear drivers side valve cover and a 'T' fitting to connect everything together above the passenger side valve cover for less than $20. I'm sure it's not perfect as far as an engineering aspect but it'll work until I get a catchcan and redo everything
Old Dec 23, 2014 | 09:01 PM
how did u make the pcv valve work the one side is bigger than 3/8
Old Dec 23, 2014 | 09:17 PM
HUMBL57's Avatar
My '99 only has a pcv grommet on the rear drivers valve cover. Passenger side valve cover just has 2 hose barbs inboard near the intake one points forward and one rearward. The forward barb just had a short hose going to TB. The rearward barb was merged into the stock plastic hosing that broke apart so I just used the T vacuum fitting to connect it to the longer hose from the PCV valve on drivers side valve cover. Routed the hose behind the intake. I can take pics tomorrow. It's pretty dark
Old Dec 23, 2014 | 10:38 PM
Majestic9C1's Avatar
I did the LS6 PCV conversion..
I had to cut the block but the part you cut has no bearing whatsoever on the functionality of the engine... took me 5 minutes with a dremel..
$100 for the parts and its a much better setup than the factory LS1 crap...
plus it cleans up the engine.
Old Dec 25, 2014 | 08:35 PM
u got pics?
