coolant crossover
Old Jan 1, 2015 | 06:36 PM
gmoutdoorsman's Avatar
Default coolant crossover
So im trying to figure out what route I should go with the steam crossover on my build. Ive heard blocking them off will fry your engine. Ive been told I need to block the rears and only connect the front of the heads.i still have the stock 4 corner crossover pipe and im putting a carb intake on so no worries about clearance.
Old Jan 1, 2015 | 09:45 PM
Paul Bell's Avatar
That's MISTER MODERATOR
No, blocking the rears will not fry your engine, most engines come from GM with the rears blocked.
Many builders, including me, prefer to utilize four corner cooling.
Old Jan 2, 2015 | 05:58 AM
Ok then ill retain the 4 corner system my 5.3 came with. Thank you sir
Old Jan 2, 2015 | 11:09 AM
wayneSS's Avatar
I found an awesome coolant crossover kit on eBay.
Old Jan 2, 2015 | 11:20 AM
josh4ku's Avatar
I'm just going to buy a 97-04 gm 4 corner crossover on eBay.
Old Jan 2, 2015 | 11:23 AM
wayneSS's Avatar
What intake are you running? Just curious
Old Jan 2, 2015 | 11:25 AM
wayneSS's Avatar
My wife bought me the Typhoon for Xmas! I heard good and bad things about it. Guess just have to install it to see for myself
Old Jan 29, 2016 | 03:21 PM
Mike Blanco's Avatar
You find one?
 Michael S. Palmer
Old Jan 30, 2016 | 11:17 AM
LS6427's Avatar
Originally Posted by Mike Blanco
You find one?
http://www.ebay.com/itm/W33-Steam-Vent-Kit-4-AN-Complete-LS1-LS6-LS2-LS7-LM7-Coolant-Crossover-BLACK/141331552125?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D33876%26meid%3D1d5c9196679f4d17a56164a54ad75a30%26pid%3D100005%26rk%3D1%26rkt%3D5%26sd%3D131490261839
