gmmg vs true duals
Cold road and it is a cell phone video but it sounds pretty good. I have 1 3/4" pacesetter LT's, TSP ORY, a 3.5" Classic Chambered powerstick (like torchd), and GMMG catback. At high RPM it actually takes on the tone of the powerstick quite a bit. I had 2.5" powerstick duals on my Formula for a while and I can hear it compared to my friend who has GMMG and an extra GMMG resonator in the I-pipe. His is far more aggressive with more bass at idle. Food for though as well, the GMMG resonator is only 2.5" ID. I personally wouldn't put one in my I-pipe.
Nursing the 3rd gear synchro. Shifts are at 6600. I don't have any idle videos but it is rather tame for a GMMG car. It has ported 5.3 heads and a baby cam.
Remove the carpet and its a completely different story. You'll NEED earplugs or muffs at that point. I know. I did it.
Jake, a kooks Y pipe is 400 bucks and the gmmg exhaust system is 750 bucks. It's only a 50 dollar difference between the two!!
When I looked at the ARH 1-7/8" setup with the ARH Y-Pipe and the GMMG exhaust... it was 2100 shipped...
Setups:
TSP- Pacesetter LT's, x-pipe, bullets, dumped before axle
GMMG - Pacesetters, magnaflow high-flow cats, late model y magnaflow merge, GMMG
TSP outside garage
GMMG outside garage
TSP inside
GMMG inside
Now, I wish I had the TSP inside the car, but my gopro was acting weird at the time.
GMMG inside short romp
GMMG under car
I was trying to get some driveline and pinion angle footage, but since I had the camera mounted on the sway bar, it didn't come out like I wanted.
I really wish I had the luxury of going with the Kooks originally. I HAD to get the exhaust done before I could register the car & couldn't afford the $$ at the time. The GMMG has a touch of rasp that I'd rather not have, but it isn't as bad as the drone the TSP had (angled down, not out).
http://madhammer.com/pages/mad_hamme...2-02_cama.html
picked up a 3" true dual setup and going to put on either a pair of borla XR1's 40943
or
kooks bullets R300-10
leaning more towards the kooks just since i can get both of them for the same price as a single borla xr1
https://www.holley.com/products/exha.../70501413-RHKR
