LS6 install and now a hissing noise?
John_D i think you hit it right on the head. i drove the car back down to fort hood(did the work in dallas), and never turned the AC on. turned it on today, and presto, no ac in the dash(works on the feet tho). which hose are you referring to? have a feeling thats exactly the problem. can anyone tell me if its possible to discern this hose from the rest w/o taking the intake back off....my hands are already looking like shredded meat from the install(forgot to file down the block after i took the EGR mounting bracket off, and never did file down the posts that keep that plastic lip on at the bottom of the windshield). Don't wanna have to take the intake off again lol. BTW my car idles fine.....but you should check your brake booster vacuum hose, i know i forgot to check mine the first time and it barely ran, had to gas it to keep it runnin, but i had forgot to re-connect it...now it runs perfect.
I have the Weiand intake, which also doesn't have the AC vac line provision.
I "T"'ed into the fuel vapor vac line on the driver side of the intake, and everything works peachy.
Bad30th
At the driver side of the intake right behind the TB there's a vac line that extends to the fuel evap. Just "T" into that and extend the vac line from the pass side under the TB and into the "T" fitting :
Hope this helps !
Bad30th
