Where does the purple wire go?
Old May 29, 2004 | 09:51 PM
cgworth's Avatar
Question Where does the purple wire go?
this is a 98 pcm and engine
I am doing a swap and need to know where the purple wire on the passenger side goes. it is in the sam sleeve as the O2 sensor wire , crankshaft position sensor and low oil sensor ( i think thats what it is) , it has a ring clamped on the end of it and kinda looks like a ground wire but its purple. does it maybe go on the starter?
Also the harness that goes from the battery to the starter and alternator- there are 2 wires around the alternator , does both go on the alternator or is one a ground?
Old May 30, 2004 | 08:25 AM
cgworth's Avatar
ttt..
Old May 30, 2004 | 05:17 PM
CamaroCain's Avatar
well if its a thick(bigger than o2 wiring) and it has a ring terminal on the end, it is the wire going to the S terminal on the starter. Now the o2 sensor has a purple wire going to it, but should be thin and would not have a ring terminal on the end. no purple wires for Crankshaft position sensor. What color are the two wires near the alternator, you normally just have the thick red wire with ring for the bolt on the back of the alternator and the thin red/brown colored wire with the connector on it that plugs in the back as well. Good luck!
Clint
