Cam sensor single or 3 pole?
Old Feb 9, 2015 | 12:09 PM
TXCatfish's Avatar
Default Cam sensor single or 3 pole?
I'm having someone order me a timing chain and he's asking if I have a single or 3 pole?
Anyone know?
It's a 01 Camaro SS
346
Thanks!
Old Feb 9, 2015 | 12:28 PM
cacmanjr's Avatar
On an LS1 the cam sensor is in the rear of the engine. LS2 and up are in the front hence the different timing gears.
Old Feb 9, 2015 | 12:35 PM
TXCatfish's Avatar
Okay do I tell him single or 3? I just realized this is "external engine".
Old Feb 9, 2015 | 07:44 PM
S10xGN's Avatar
Sounds like the guy is asking about the cam sensor reluctor built into the gear. If the car in your sig has the stock wiring/ECM, it doesn't matter (as long as it's a 3-bolt gear) because your sensor reads the reluctor on the rear of the cam...
Old Feb 9, 2015 | 07:51 PM
Paul Bell's Avatar
That's MISTER MODERATOR
In the LS1 & LS6 engines, the cam sensor is at the ear of the cam.
Your cam gear has zero bumps or poles on it.
