Anyone Running A Vette LS2 Water Pump With F-Body Alternator?
Need some more clearance between water pump bell and my DP. What do I need to fit the Vette WP with the flat bell and retain the F-body alternator mounting? I realize the tensioner will need to be spaced out but not sure if the belt will fit the bell.
TIA
TIA
Pretty sure that's the water pump I had to run with the aster bracket for my procharger. I remember all I had to do was use a pulley puller and pull it out off the shaft some. Contact Bob from brute speed. He'll be able to tell you for sure.
