Larger Throttle Bodies.
Old Feb 9, 2015 | 10:27 PM
Need4Camaro's Avatar
Default Larger Throttle Bodies.
I was just curious if there are any larger throttle bodies that would be plug and play for LS1 FBody's out of trucks or maybe even vettes or is the only way to go up either P&P or aftermarket? - Just curious here is all.
Old Feb 10, 2015 | 05:31 AM
HCI2000SS's Avatar
The only plug and play is to use the stock or aftermarket TB in similar size. Just have the stocker ported is your best bet IMO
Old Feb 10, 2015 | 04:59 PM
01ssreda4's Avatar
Most larger stuff got the 4 bolt pattern which is why it won't bolt up.
Old Feb 10, 2015 | 08:47 PM
skopers3's Avatar
I bought a FAST 78, which is larger than stock and bolts up to a stock manifold. I don't know that it made any noticeable difference, but sure looks pretty.
Old Feb 10, 2015 | 09:43 PM
JoeNova's Avatar
Restricted User
http://www.ebay.com/itm/Billet-Aluminum-LS1-TO-LS1-3-Bolt-to-4-Bolt-Throttle-Body-Adapter-/171541710445?pt=Race_Car_Parts&hash=item27f0aec66d&vxp=mtr
The LS2 throttle body is ~90mm.
Old Feb 10, 2015 | 10:17 PM
VandykeT/A's Avatar
LS2 is drive by wire isn't it? Porting it is simple I've done dozens.
Old Feb 11, 2015 | 07:49 AM
01ssreda4's Avatar
Originally Posted by JoeNova
Yuck....
Old Feb 11, 2015 | 08:31 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I'd just be happy to find an LS2 TB under 200 bucks...
I'll never for the life of me understand why the older PCM's can't be recalibrated to run a gold blade
