Throttle body doesnt close
How far past (backward/inward) vertical does the TB blade go?
If this is a small amount, the throttle body stop has an adjustable screw which needs to be adjusted so that the blade is slightly opened at idle.
If the blade itself is mounted the slightest bit off center, it will bind in the throttle body. Check the two small screws holding the blade to the shaft.
You should also be able to adjust the stop screw on the throttle body.
Another option might be to adjust your throttle cable length.
More than once, seemingly out of nowhere, my wife has offered her opinion about a car issue. She was correct, so I listen more carefully to her.
