VMAX CNC Ported Throttle Bodies
Only $150 plus shipping.
Two options are available:
1. A direct sale
(ship your throttle body in & we immediately exchange it for a ported unit)
or
2. We can ship you one prior to sending your throttle body in,
by billing a refundable core charge (if returned within 2 weeks).
Core charges:
LS1 & LS3 $200
LS2 $400
Feel free to PM, text, email, or call for more information.
This is CNC porting done precisely by a machine. It does not have the inconsistencies that hand porting can also create.
These porting profiles were tested on a flow bench to verify results so they are a proven repeatable result.
Anyone with a cartridge roll can make a throttle body shine... This may or may not cause any improvement in airflow. They can also ruin the precise area of the butterfly, making idle difficult or inconsistent.
The art of porting is knowing what works & what doesn't... Mostly through hours of testing & verifying.
"The following is a break-down on what goes into one of our modified throttle body's
Throttle body is completely disassembled and cleaned
Ridges and casting lines on the top and bottom of the housing are removed for a cleaner look.
Housing is ran thru a media-blast cabinet for a "better than new" appearance.
Throat ported, smoothed and inlet blended to a performance finish.
Blade has been sanded smooth and thinned so there is no need for a "knife edge" modification.
Bump stop cut for a fully open throttle blade at wide-open-throttle.
Shaft halved to cut down on air restriction.
OEM blade screws removed and replaced with stainless screws / washers and then thread locked.
Available FREE options.....
FREE ..... Polished spring or Colored ..... NO Charge
FREE ..... Coolant lines cut/removed and rubber capped ..... NO Charge
Also Available.....
Accessory fastener kit..... only $4.99 extra
Coolant line by-pass kit.....only $3.99 extra
Intake bolts .....only $7.99 extra"
..... & here is their return/customer satisfaction policy ...
"If for any reason you are not completely satisfied with your purchase or my attempt to correct any issue that may arise, you may choose to return your item(s) for a full item price refund (refund excludes the original shipping cost). I know life gets hectic and we all get busy, so i now offer a 14 day from the date of the documented delivery return policy. Cant find the time to install your t/b right away? No hurry with a 2 week return window. Product questions or a problem with installation? No worry! My goal is to provide excellent customer service before, during and after the sale. Your phone calls and emails will receive the same attention even after delivery as they did leading up to the sale.
I firmly believe that our porting service is by far the best being offered anywhere and at a price that is unmatched. All this without all the drama or history that some of the competition brings along with them. In fact, I am so convinced that we offer the best product available, that I will extend this offer.....
Purchase one of our throttle bodies and check it out. If it is not what you expected or we can't resolve any issue that there might be, please feel free to return your part for a full item price (refund will exclude the original shipping cost) refund with no questions asked. You can even keep the stainless sensor screws that came with it. No Questions Asked.".
.....so are you stating that you somehow have created a better / higher flowing product? just asking, as that is what it seems you are saying in your initial response. if so, then maybe its worth double the price to some i guess.
Also Available.....
Just to be clear, I am not the manufacturer but a dealer of this product.
VMax is not a sponsor here, so they will not be responding.
No one is hiding.
HP results on an LS1 applications range from 8-12rwhp.
If you search there are many independent magazine articles/tests confirming this result.
Many are listed on the Vmax website for your review.
As with any product there are many available options... if you like another product, then buy it. Its a free country. This is not politics, its free enterprise... no need for us to bash another competitor, even though we have enough test data of many competitors to do so.
Also SkWiDsTyLe321, you have the right to your opinion. If you want to buy the 1/2 price option, feel free... just don't make the incorrect statement that both are the exact same product. Until you own/operate a flowbench, or have independent back-to-back performance test results, you are not qualified to make that comment.
... the other was a sarcastic response to a lame put down comment aimed towards me by another forum member - no biggee. so, actually, i'm 100% "qualified" to make the statement/opinion that i did. you gave your answer, which is great. now people have info on 2 products & they can make an informed decision about which one they would like to purchase.
Porting programs have been developed for virtually every LS application as well as some GM & Cadillac V6 applications.
