TSP 1 7/8 vs Speed Engineering 1 7/8 Headers
#41
That thread should give you all you need. I haven't done mine yet, just got the ball and socket collectors in the mail today and should have it all finished by the end of the weekend.
#42
https://ls1tech.com/forums/generatio...cats-home.html
#46
I've owned both tsp and speed engineering and noticed no difference to make it worth paying extra for tsp. They are both Chinese made and probably by the same company.
#47
I haven't owned either one but from the pics, looks like the TSP are a bit more equal length than the SE headers? The pipes on both rear cylinders a little longer on the TSP
#48
My SE LT's came in on Monday. As others have mentioned, the exterior welds are very nice and the headers look very nice. My SE 1 7/8" LT's weigh just over 10lbs each. I am a little picky and ended up touching up the inside welds a bit where the flanges meet the tubes and also removed a few boogers on the inside where the tubes meet the collector.
Shipping and handling leaves a lot to be desired. Both tubes were in bags, but the headers, gaskets and bolts were in a box loose with only one piece of cardboard between the headers. I'm shocked that my OEM Gaskets were not damaged. One of the collectors had to be straightend out a little bit too. I'm also underwhelmed by the included bolts and will be using some better ones with larger hexes and flanges.
My biggest concern is that these tube are not seamless tubing. They were not specified as seamless tubing so I cannot be upset about this. So, this seems to be the main difference between the TSP and SE. If I had known for a fact that these were not seamless, I may have sprung for the TSP's.
Overall I'm happy with these and I think they are a great value. Hopefully the install will go smoothly.
#49
#50
This weekend, i swapped a set of 1 7/8 tsp long tubes for a set of speed engineering headers. I did it in an attempt to reduce under hood temps... i wrapped the speed engineering headers.
The collector locations were different, the speed engineering ones were forward in the car around 3-4", meaning they did not perfectly trade spots. I had to do some cutting and welding to get the exhaust to mate up.
Buf overall, they fit just as well as the tsp pieces.
#51
#53
I installed SE LT's this winter on my WS6, Couldn't be happier for the price. Runnin cat-less Y into a borla muffler and the sound is absolutely amazing. Doesn't drone out on the interstate (M6 with 3.42s) Which I was extremely surprised about. I used studs instead of bolts for mounting it to the head which was WAY easier getting them set by myself. They're not the lowest point on the car either, might just be my personal setup but a section of the Y will scrape before the collector or any part of the longtubes will. Only thing I would suggest would be using lap-style clamps on every part. I battled exhaust leaks until finally ordering lap-joint style
#54
SE LT's install went smoothly. I did poly mounts at the same time... along with Hooker BH duals. As far as the header install went, I had to remove the steering shaft to get the driver side in. And of course I removed the starter on the passenger side. I did the install 100% solo. I took two 8mm bolts and turned down(on a lathe) the head down to little bit larger than 8mm. I screwed the bolts through the gaskets to hold the gaskets in place and also to hold the header in place when I get it in position. I inserted my new header bolts in the other 4 locations and then removed my modified bolts and installed the last 2 header bolts. Worked like a champ.
#56
