5.3 carb maf
Old Apr 9, 2015 | 03:15 PM
Paul1980's Avatar
Default 5.3 carb maf
I'm putting a 5.3 in a 1980 camaro...its carburated with the msd 6010 kit...wondering if I had to run the maf sensor if so what kit can I use
Old Apr 9, 2015 | 06:14 PM
Paul Bell's Avatar
That's MISTER MODERATOR
When you say MAF, do you mean MAP??
The kit instructions show a plug for a MAP sensor but it doesn't list a MAP sensor in the parts list. It also says it's optional.
I would think this means it'll work without a MAP. However, I'll bet it runs better with one.
Old Apr 10, 2015 | 02:48 AM
Paul1980's Avatar
Mass airflow sensor
Old Apr 10, 2015 | 05:56 AM
Paul Bell's Avatar
A MAF is needed to adjust the fuel curve. As the MSD kit is for spark only, is doesn't include or need a MAF and there's no way to connect it to a MAF.
Why do you think you need a MAF with this kit?
