MAF question
Old Apr 8, 2015 | 04:49 AM
nj02z's Avatar
Default MAF question
I mail ordered a new AC Delco maf sensor for my wife's 99 Z28.When I received the sensor it looks nothing like the stock sensor /housing. The new one is plastic and has a different design. Did GM redesign this or should I send this back and go to a dealer?
Old Apr 8, 2015 | 03:55 PM
SAPPER's Avatar
PIC and Part# please. I work in a GM parts dept.
Old Apr 8, 2015 | 04:13 PM
jimmyblue's Avatar
Moderator
Unlikely that it's a proper replacement, more likely
a dumb online ordering experience. If it has a three
prong plug then maybe somebody's decided to go
after the aftermarket on these finally, but if it's a
5-pin connector then it's just a wrong substitution.
Old Apr 8, 2015 | 05:29 PM
nj02z's Avatar
I did a search on AC Delco web site and it shows the new replacement in plastic with a 5 prong plug. The sensor came with an adapter to go from 5 to 3. The actual electric piece does say AC Delco. I read that it is now made in plastic to combat heat soak.
Old Apr 8, 2015 | 10:25 PM
kinglt-1's Avatar
The Delphi AF 10056 is the stock replacement. The original metal maf with air foil is discontinued. There are few threads about it floating around.
Old Apr 10, 2015 | 01:30 AM
99 ss's Avatar
So is these new ones better for our ls1 f-body's if so then I'll replace mine
Old Apr 10, 2015 | 04:27 AM
nj02z's Avatar
Not sure if it is better but my wife's car went way lean at wot. Puledl the maf off my car and solved the problem. When I ordered a new AC Delco maf it is not the same. After doing some searching it seems GM discontinued the original metal maf and replaced it with a plastic version. I checked on the AC Delco website and the maf that I received is as pictured on there website. The new maf and a built in IAT but it comes with a pigtail to converter from 5 pin to 3 pin. Thank goodness for the wideband.
Old Apr 10, 2015 | 09:48 AM
kinglt-1's Avatar
They claim its calibrated just like the original, but if it flows more air due to larger internal opening, I assume it will best to tune it or else the car will lean out as mentioned.
