What Intake is best for a cam only ls1?
Drag? Streetable?
I've done the 102/102 with heads and cam and it was so hair triggered after. I'd do a 92/92 next time.
Mamo ported +16-18 hp, FAST 102 12-15, Mamo Ported 102 18-20,
Again on stock cube, medium+ Cam only.
FAST 102 needs fuel rails, other accessories,
+ VMax velocity ring with 90 MM TB
For easiest tuning and best throttle response.
102TB overkill For less then 500+RWHP IMO.
Tony's Porting on FAST intakes picks up everywhere on the
Curve! Torque at the bottom, and HP at the top! almost double
The gain over FAST alone!
Did you have the V Ring with your 92TB set-up?
The ring is designed to eliminate the step and reversion
Prior to entering the Plenum itself, Just wanted to clarify
Whether you had the ring prior to picking up 7 HP with the change.
It will but if he wants the best a 92 wont yield the most power.
Get more of a notice in change spending equal money on the diff and gears and go from 3.43 to 3.9 or 4.11.
My current 408ci does have a 92/92 fast as it came with it the built engine done 8 years ago now.
I just wished we had blokes here in Australia like Tony Mamo , but, there is no one that I know over here like that here.
agree on the intakes. if money is no object, $1.5k on fast intake/tb might pickup a little, but spent elsewhere, like even setting the car up for traction, can gain a lot more.
Everyone knows the ls6 works fine but that doesnt mean a fast wont gain a good amount. 5-10 hp is extremely low for a gain on a cam only car when going ls6>FAST
a bit like our government also f*cks us twice as hard as yours. enjoy your freedoms (and cheap HP) while you still have it over there
