4150 tb needs blades drilled
I just had this issue with my car as it has a big hyd. cam and an edelbrock 4150 tb. I adjusted the idle screw as mentioned above and also tweaked the tps sensor to get the car to idle correctly at a desirable rpm range. Haven't had any issues since.
I have the fast 4150. I tried adjusting the blades but tps isn't happy about it. I was told by patg to drill the blades. Cause I love open the blades and iac stay maxed
