Is this an Intake Leak?
Old Apr 30, 2015 | 03:29 PM
onesloGTO's Avatar
Default Is this an Intake Leak?
Bad intake gasket?:
What do you guys think?
No fluid leaks, just the smoke.
Old Apr 30, 2015 | 05:12 PM
99Bluz28's Avatar
Does it smell like coolant, or is the smoke oily ?
Old Apr 30, 2015 | 05:18 PM
onesloGTO's Avatar
Smells oily
Darth_V8r's Avatar
Moderator
Almost looks like blow by gases coming through the valley cover gasket or front timing cover gasket right above the water pump. Your PCV plugged or the vacuum line between the PCV and intake broken?
Old Apr 30, 2015 | 05:35 PM
99Bluz28's Avatar
Imo, after watching the video a bunch of times, it looks like its coming from somewhere around the top center to top right side of the timing cover.
Old Apr 30, 2015 | 05:52 PM
onesloGTO's Avatar
Ok, maybe just try to make sure everything is tight?
Old Apr 30, 2015 | 05:55 PM
ULTIMATEORANGESS's Avatar
best way to tell is to get a smoke machine.
Old Apr 30, 2015 | 08:58 PM
an-i-no's Avatar
If you take off your oil cap does the smoke come from there as well? Looks like crankcase gasses to me maybe?
How is your PCV system setup?
Old Apr 30, 2015 | 09:21 PM
onesloGTO's Avatar
I'm thinking crankcase now too. The breather is smoking like crazy now. Thinking my rings are shot. I have a hose off each valve cover running to one catch can/breather.
Old Apr 30, 2015 | 09:33 PM
onesloGTO's Avatar
Yes the smoke comes out like a train with the oil cap off, but stops smoking from the intake area. Smokes so bad it fills up my garage with 2 does open.
Old Apr 30, 2015 | 09:43 PM
an-i-no's Avatar
Yeah then it's definitely crankcase gasses/blow by. When you take the cap off it gives it somewhere else to escape from.
Sounds like rings/ringlands unfortunately I would try a compression test, and then another compression test with a little bit of oil in each cyl before you tear it apart though. May be something simple.
Did this just start suddenly?
Old Apr 30, 2015 | 09:57 PM
onesloGTO's Avatar
I just did a compression test a few weeks ago. I've owned the car just a few months. For the past month its been having problems. Finally got it running decent.
It's smoked a little but has been getting worse.
Old Apr 30, 2015 | 10:15 PM
an-i-no's Avatar
Ok I watched the vid again. I see Corvette accessories and a turbo so first check this out https://ls1tech.com/forums/generatio...ting-ok-4.html
Old Apr 30, 2015 | 10:38 PM
onesloGTO's Avatar
I read some of it and looked at the diagrams. But I don't really understand that stuff.
Old May 1, 2015 | 12:21 PM
Darth_V8r's Avatar
Moderator
PCV needs vacuum to work. If you are boosted, you might not be getting vacuum to your PCV, so the gases build up in your crankcase and find a way out anywhere they can. You probably need to be drawing vacuum from between your air filter and turbo if you aren't.
Also, verify the hoses are intact and the valve isn't plugged or stuck
Old May 1, 2015 | 12:44 PM
onesloGTO's Avatar
I'll draw something up on how my hoses are routed so you guys can tell me if it's right.
Old May 1, 2015 | 04:05 PM
onesloGTO's Avatar
Here is a shitty picture of how things are routed.
Old May 1, 2015 | 05:22 PM
Darth_V8r's Avatar
Moderator
Looks like you have nothing pulling from the crank case, so your PCV is not doing anything. Try this equally crappy drawing for what should work to fix it. Eliminate the hose with an X through it. Add the yellow and orange hoses. The orange hose should connect between the filter and turbo for vacuum. You will need a one-way check valve in the yellow hose to make sure the airflow is only toward the throttle body
Old May 1, 2015 | 09:33 PM
onesloGTO's Avatar
Should this be capped?
Old May 1, 2015 | 11:11 PM
kinglt-1's Avatar
No that is suppose to connect to the passenger side valve cover. It looks like to me the entire PCV system has been deleted or something. Google "LS1 PCV System". Plenty of diagram pics out there.
